BNIB GSR Rods and SRP Pistons
Old Dec 28, 2010 | 07:31 PM
sanjiyan69's Avatar
Default BNIB GSR Eagle Rods and SRP Pistons
SRP pistons P/N 149226
- 11:1 CR with B18C1/C5 head.
- 9.8:1 CR with B16 head
$400 shipped OBO
GSR stock length Eagle rods. Brand new in box.
$300 shipped.
Old Dec 31, 2010 | 09:44 AM
sanjiyan69's Avatar
Default Re: BNIB GSR Rods and SRP Pistons
bumpity.
Old Dec 31, 2010 | 11:05 AM
RyanA's Avatar
I think you mean 10.8 and 11.1 compression; not 9.8 and 11.1.
GLWS
Old Dec 31, 2010 | 01:01 PM
sanjiyan69's Avatar
thanks for checking. I was just going with what SRP.com says.
http://www.jepistons.com/Catalogs/SR...6a1-a2-a3.aspx
Old Dec 31, 2010 | 02:01 PM
RyanA's Avatar
OK, I see where that came from. Here you go:
B16 engine with B16 head: 9.8
B17 engine/head: 10.0
B18A1/B1: 11.0
GSR engine/head: 11.0
ITR engine/head: 11.0
Those are the compressions they list on stock engine/head combos (seems kind of odd that the GSR and ITR engines list the same compression since they have everything the same except for the head; the GSR should be slightly higher). If an engine comes with a B16/ITR head but you'll be using a GSR head, add approximately .2-.3 compression. If it originally was fitted with a GSR head but you have a B16/ITR head, it will be about .2-.3 less compression.
Old Jan 2, 2011 | 05:11 PM
sanjiyan69's Avatar
bump. buy these from me!
Old Jan 4, 2011 | 06:02 AM
sanjiyan69's Avatar
bumpity
Old Jan 5, 2011 | 08:54 PM
sanjiyan69's Avatar
bump
Old Jan 10, 2011 | 06:44 PM
sanjiyan69's Avatar
keep bumping!
Old Jan 17, 2011 | 06:55 AM
sanjiyan69's Avatar
bump!
Old Jan 22, 2011 | 05:32 PM
sanjiyan69's Avatar
bump again!!!
Old Jan 23, 2011 | 10:06 AM
EJ1_Ex's Avatar
these pistons are 81mm if they were 81.5 i will take the pistons..
Old Jan 23, 2011 | 10:26 PM
sanjiyan69's Avatar
yeah sorry man, 81mm these are...
Old Jan 30, 2011 | 12:33 PM
sanjiyan69's Avatar
Bump for NHL All-Star game.
Old Feb 5, 2011 | 09:08 AM
sanjiyan69's Avatar
bump for nothing.
Old Feb 6, 2011 | 11:33 AM
sanjiyan69's Avatar
Super Bowl bump!!!
Old Feb 8, 2011 | 05:00 PM
sanjiyan69's Avatar
bump for Michigan State playing like ****.
Old Feb 15, 2011 | 03:20 AM
sanjiyan69's Avatar
up!
Old Feb 18, 2011 | 05:15 PM
crxking1's Avatar
bump
Old Feb 18, 2011 | 07:56 PM
sanjiyan69's Avatar
bump again1
Old Feb 19, 2011 | 06:36 AM
revolution920's Avatar
hmm i have some one that might be interested pm plzz
Old Feb 21, 2011 | 07:06 PM
sanjiyan69's Avatar
bump!
Old Feb 21, 2011 | 08:35 PM
562SkankDC2's Avatar
eagles.....are those the big bolts(7/16)??
Old Feb 22, 2011 | 04:47 PM
sanjiyan69's Avatar
not sure. it comes with ARP bolts from Eagle. does it make a difference? Let me know and I can check.
Old Feb 22, 2011 | 06:57 PM
yea the newer style eagles are made jus a bit stronger and to handle a bit more power...the big bolt uses a 12point 7/16socket and the older style has the smaller bolts that uses the 12point 3/8socket if theyre the big bolt ones ill take them off ur hand 280$ shipped
