92 integra parts
im going ls/vtec so im pretty much getting rid of the ls parts...
let me know what you need and ill let you know if i got it...
everything is still assembled so you can see its working...
-distributor
-92 ls head-can part out, cams, cam gears, valve springs.
-oem spark plug wires
-spark plugs
-oem water pump
-recently replaced timing belt and tensioner
-oil pump
-stock intake manifold
-stock intake with new filter
-stock ls b18b1 pistons, have about 95k miles
-i also have a used GSR dc headers and extra GSR dual valve springs(one side dual only)
-distributor
-spark plugs
-oem water pump
-oil pump
