B18B swap fuel line questions
The fuel line is spraying gas out where it connects to the fuel rail. I used the stock fuel line from my 95 hatch, do I need the fuel line from the ls, or something else?
Sometimes you can reuse the Civic fuel line, sometimes you can't. Some of them used a damper pulsation nut at the end of the fuel rail, some just have a plain nut/cap. The lines have different ends depending on which style nut is used.
It was the washers D= imma noob, I know. It started up fine but its still spraying a little gas, I tighten the damper pulsation nut all the way and the hose it's self is in good shape, any suggestions?
Washers are on both sides, I tightened it a little more and that seemed to do the trick. It's starting to smoke now by the header, idk its just gas or what D=
Luke G.
14
Sep 10, 2009 06:07 PM
h22acivichybrid
Jun 14, 2004 03:20 PM
