Valve Covers, turbo accessories, strut brace, ETC!
Old Dec 26, 2010 | 06:24 PM
WrongWD's Avatar
Icon6 Valve Covers, turbo accessories, strut brace, ETC!
GM Boost Control Solenoid
Control Boost via Neptune, Hondata S300, etc with this solenoid.
$15 Shipped
PWR Intercooler
One half painted black. A little bent, a little ugly, but holds air perfectly. That's why it's so cheap for a genuine PWR.
$80 + shipping OBO
Fastline Oil Pan Baffle Set
Never installed. They have a little bit of surface rust, but 30 seconds with a scotch-brite pad before you weld
them in will clean it up.
$20 Shipped
Boost Leak Tester
Custom made. Just hook it up to a compressor or air tank and listen for leaks. Includes cap for throttle body end
of tubing. Made for a 3" compressor inlet, and a 2.5" charge pipe near the throttle body.
$25 Shipped
Earl's -4 Oil Feed Line
33 inches from fitting to fitting. Good for a larger feed line.
$15 Shipped
B16A3 Valve Cover
Painted red over the factory black wrinkle finish. Not pretty on the outside, but super clean on the inside.
$55 Shipped
D16 "HONDA" Valve Cover
Pretty clean, never painted or modified.
$40 Shipped
B16A3 Intake manifold and throttle body
Good condition. This is the manifold you need to pass the California BAR inspection with a B16 because it has the
fitting for an EVAP purge valve. Sensors included are: MAP, TPS, IAT, FITV, IACV and lower brace bracket. No EVAP
purge valve.
$85 Shipped
Neuspeed Strut Tower Bar
Fits 92-95 Civic, 94-01 Integra, and 93-97 del Sols. Good condition, painted satin green. Solid design mounts to upper control arm bolts. No joints like other strut tower bars, so this is a much stronger design.
$75 Shipped
All prices are OBO. Contact Jon at (206)849-1123 with offers! Thanks for looking!
Old Dec 28, 2010 | 07:43 AM
WrongWD's Avatar
Default Re: Valve Covers, turbo accessories, strut brace, ETC!
bump
gotboost95
Jun 23, 2011 05:10 PM
WrongWD
Aug 24, 2010 07:56 AM
WrongWD
Aug 24, 2010 07:55 AM
Dmc1
Jan 26, 2006 11:39 AM
TurbothisLS
May 10, 2003 01:18 AM
