smokey start
Old Dec 26, 2010 | 03:21 PM
patrick_irwin's Avatar
Default smokey start
Alright I bought a 89 sedan a while back been dailying it for a while. Well when I bought it the oil light kept popping on and off but the car didn't smoke that bad only when it started. but now after time it seems to be getting worse.
So now Im home for Christmas break, and I decided I was going to figure out the problem. I pull out the spark plugs and the bottoms were soaked in oil... along with the spark plug wires. Which makes me think that its the head gasket. Or could it be more? I tightened them down to specs and now the wires dont have oil on them except cylinder 1. I'm not a 100% sure that its the head gasket because oil isnt seeping out of the motor.
I just need a little help, I don't think its the piston rings but I could be wrong. I'm leaving tomorrow to go back to school so I need info asap. I was planning on rebuilding the motor this summer, can it wait or should I attempt to replace it tomorrow?
and for anyone that wants to see the car
Old Dec 26, 2010 | 04:05 PM
Default Re: smokey start
bump.... seriously no input???/
Old Dec 28, 2010 | 05:44 AM
crxfreak1117's Avatar
smokey start, most likely valve stem seals,
oil light off and on?, low oil, oil pump goin out, bad oil pressure sending unit
oil on spark plugs/wires, probably your valve cover gasket (spark plug hole seals)
Ef4doorwagon
11
Jan 14, 2014 07:24 AM
projcinco
Aug 28, 2008 06:10 PM
ALLMOTOR CRX
Feb 24, 2007 08:59 PM
pane93civhb
Jul 19, 2005 12:32 PM
just4747
34
Jan 27, 2005 10:02 AM
