Transmission & Drivetrain Gearboxes, Differentials, Clutches
cable bell housing on hydro case?
Old Dec 26, 2010 | 08:16 AM
evane151's Avatar
Default cable bell housing on hydro case?
I just got a 89 si (cable car) with an ITR motor and S80 hydro tranny. Car has HASPORT cable/hydro conversion. Works but not comfortable, pedal too stiff and no feel and not any fun. Wanting to put a 92-93 Integra YS1 cable bell housing on my S80 with LSD hydro case. This would keep me all OEM cable with hydro case and interals. I would have to adapt the cable bracket to the hydro case, but that may be easier than swapping internals. I would rather have OEM cable rather than cable/hydro conversion or all hydro conversion that requires cutting the car up and no a/c or defrost on driver side. Bad knees and I need the OEM pedal feel, not stiff cable breaking pedal effort required by the cable/hydro conversions. Why has nobody just changed the bell housing so it will be all cable, can it be done?
Old Dec 26, 2010 | 08:55 AM
FishaCrx's Avatar
Default Re: cable bell housing on hydro case?
Yes, yes it can search. The hydro internals fit inside a ys1 case(cable case) with some modification.
Old Dec 26, 2010 | 09:18 AM
evane151's Avatar
I was stating bell housing but you are essentially spiltting the transmission case. So if I am splitting the case I might as well use the YS1 case and just place my S80 hydro interals and have all cable. Swaps... are they worth it. They are when that tach its 9500. Trailer Park Ferrari.
Old Dec 26, 2010 | 11:18 PM
Gearspeed-Performance's Avatar
I would use both YS1 cases as a matched set if you have them. Be sure to check all your clearances before sealing it all up! Good luck bro!
Old Dec 29, 2010 | 01:18 PM
sh!ft's Avatar
Who the fack changed my title?!
this is what i will be running actually in my car, but it is a FULL hydro setup with a cable case. the only difference is that i will have a hydro slave and steel braided line. everything is already mounted and linked up.
evane151
Dec 25, 2010 10:25 PM
90efcvicsi23
Dec 4, 2008 10:19 PM
Kid_SiR
26
Feb 5, 2008 10:08 PM
Crx_B1turbo
Sep 12, 2007 02:02 PM
