Suspension & Brakes Theory, alignment, spring rates....
Ground Control Stock sleeves to koni sleeves
Old Dec 25, 2010 | 09:06 PM
Iloveyourhonda92's Avatar
Default Ground Control Stock sleeves to koni sleeves
So i want to order the ground control coilovers, and put them on my stock gsr struts but later on i want to upgrade to koni yellows with top hats.. is there a site i can order the koni sleeves?
Old Dec 25, 2010 | 10:14 PM
90_EX_Civic's Avatar
Default Re: Ground Control Stock sleeves to koni sleeves
they're actually ground control sleeves made to fit the koni yellows. so you can get them from ground control
Old Dec 26, 2010 | 12:42 AM
98civdx's Avatar
Master Detailer
What my friend did, was buy the Koni spec Gc's and then just ran no name sleeves/adjusters on his other shocks untill he could afford the Koni shocks.
Ground control sells them, for around $120.
Old Dec 26, 2010 | 03:59 PM
what if i were to run just the gc spring on no sleeves, would that be bad for the spring?
Old Dec 26, 2010 | 04:55 PM
ware's Avatar
The sleeves are going to have to be Koni specific (they have a lip where they sit on the Koni shock) meaning they are designed for those specific shocks. Can you put them on other shocks? Yes. I would just wait and get everything together OR buy the shocks first and you can run a spring of your choice (oem,lowering spring, etc) Then get the sleeves and you'll have your set-up.
Old Dec 26, 2010 | 06:02 PM
98civdx's Avatar
Master Detailer
With just the gc spring, your car will be very very low.
Old Dec 27, 2010 | 07:18 PM
you think it would comprise the spring? i dont wanna break them
Old Dec 27, 2010 | 08:01 PM
98civdx's Avatar
Master Detailer
Nah, I run just a 8'' Skunk2 springs for a while, without causing any damage to the spring. Handeling, ride quality is completly thrown out the window. I almost got air born on the connection joints on the highway several times.
Old Dec 28, 2010 | 05:00 PM
haha eff that noise then lol
Old Dec 29, 2010 | 10:24 PM
lxdriver's Avatar
LOL
unc25
Suspension & Brakes
May 19, 2012 12:15 PM
Luca
Suspension & Brakes
Nov 2, 2010 04:12 PM
steve00si
19
Nov 30, 2004 07:37 PM
BoosterSH
Oct 13, 2003 09:34 AM
