want some info
k guys,dont know if im on the rite section to ask this
im running this on my 93 eg hatch :
gsr block with a b16 head
b16 tranny
i wanna make it turbo
any help on what to get im new on turbo motors/cars
i wanna pull 300+ budget isnt a problem lol
b16 tranny
Please check the FAQ stickies at the top of the forum. start looking at cars that have the same desires that you want . that's the best way to learn on this particular website, really.
TheShodan can provide you with more info than you need.
BUT you need to start by doing your own research.
Research does not mean asking people.
You know you've done enough research when things start to repeat it self and you clearly the basics of:
1) what a turbocharger does
2) what parts are all needed & how to install them
3) what ECU should you go with and why
I would research those three topics in that order and it will make sense to you.
This is 2010-2011, not 2001-2003 when seeing a boosted honda was a rare treat.
All the info you need to make 300whp is in the FAQ.
Let me know if you need more detailed instructions on how to research. We are here to help you learn, not to hand feed you what we have learned for you.
Sorry if I come off as a *****. Cheers
Just for 300whp as your goal...
...if you want someone to hand feed you the info, go to the local import shop or dyno shop and give them $2000-2500, that is all that's needed for them to have it all done including turbo kit, parts, tuned, installed and might even have spare cash for a new clutch that is a must.
If you did it yourself, you could piece together a decent kit for under $1500 and get it tune for $250-300.
Good Luck
Good Luck
yea i did some research and seems like the tune is the most important part.
.. i dont need anyone to hand feed me just steer me into the rite direction.
TheShodan did that just i guess i didnt state my question correct what i meant to say was
"i would like to run 300+ what is a good turbo setup for my motor"
i guess i needed to search couple things up and its okay u didnt come off as a ***** i just asked the wrong question
