JDM ITR rear sway bar. Need Help
So this is what the UPS lady dropped off for me today, isn't it pretty.
Anyways, those two things you see there are Honda bushings brackets. That is all I recieved from the supplier. BSQ website is currently unavailable.
So if you guys could please tell me the parts needed to complete this installation that would be great. I need it installed by Saturday for an autocrossing event. Post some pics as well if available
Alex
So if you guys could please tell me the parts needed to complete this installation that would be great. I need it installed by Saturday for an autocrossing event. Post some pics as well if availableAlex
1) 2 bushings that go on the end of the sway bar itself (one per side)
2) if you are upgrading from your stock bar you probably need different D brackets i would think
3) should be able to re-use the same D bracket bolts.
4) aren't you going to need ITR endlinks?
5) what about a reinforcement kit?
i upgraded my ITR to the JDM 23mm and it was pretty easy. Just took the stock bar off and re-used the small bushings on each side of the sway bar. the JDM unit came with new D bushings and that was it. I pressed out the stock bushings and re-used them with the new bar. worked like a charm and threw it back on the car and voila! IM me if you have any questions.
mike
mike
mike
mike
be more careful in the rain, as i swung my tail out too easily w/the 23mm on an on ramp
Since you have the swaybar and the swaybar bushings, you will only need the following parts:
3.) 52308-SS0-000 bushing bracket (2 needed)
4.) 52316-ST7-Z00 endlink bushing (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) (2 needed)
7.) 94050-08080 flange nut (8mm) (2 needed)
The same installation instructions apply for the 23mm JDM Type-R rear swaybar as the 22mm Type-R rear swaybar. Here is the link to the installation instructions: http://www.geocities.com/bretq/swaybar_install.html
Let me know if you have any other questions.
i want one too! how much did u spend overall with all the parts needed?
Are you sure I'll need these parts? Or is it required since the stock one's I have aren't ITR.
Also don't I need your kit as well?
Alright well it looks like I have everything straight. I'll be ordering your kit tonight via 2-3 air, so if possible could you have that shipped tomorrow? And as far as the acura parts go. I check with Volcom and the local Acura dealer. If not I'll check with H&A.
