Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Passenger Side Noise
Old Dec 23, 2010 | 03:23 PM
mikelemons's Avatar
Default Passenger Side Noise
2008 Accord EXL 64K miles. I have a rythmic noise that seems to be coming from the passenger side. I used a stethascope and thought I had it isolated to a wheel bearing but I replaced it and it didn't make any difference. I can get the noise with the wheel off so it's not a tire. I seem to have some movement in the inner CV joint although when I took it out, it seems tight. I did detect some play at the inner CV joint to carrier bearing but I can't tell if the play is from the bearing or from the splines. Does this model have a history of bearing or CV problems?
Thanks.
Mike
Old Dec 27, 2010 | 03:48 AM
mikelemons's Avatar
Default Re: Passenger Side Noise
Also, When I replaced the front wheel bearing, the VSA light came on. Everything looks good. Bearing is in with the magnetic area to the rear, etc. Is there a reset on the VSA that needs to happen?
thanks
Mike
fuzzysig
Suspension & Brakes
Aug 25, 2017 12:17 PM
Chef Andre
14
Dec 12, 2011 08:26 AM
PAID-$$$
Jun 30, 2004 09:12 AM
