Winter Air Pressures, Don't Forget Your Spare
Old Sep 23, 2002 | 12:24 PM
nsxtcjr's Avatar
New User
Default Winter Air Pressures, Don't Forget Your Spare
Just a reminder - as temperatures drop, tire pressure drops as well - by roughly 1 psi for each 10 degree drop in temperature. For many of us, normal temperatures drop significantly this time of year. Don't forget to check your tire pressures and add air as needed to maintain the pressure you prefer.
Also - DON'T FORGET THE SPARE! The space-saver spare tire is supposed to be inflated to 60 psi. It may be out of sight, but don't forget to check it every once in a while. Better to check it now while you can get around, than find out it's too low when you have a flat out in the middle of nowhere.
Old Sep 23, 2002 | 12:26 PM
Chris N's Avatar
Default Re: Winter Air Pressures, Don't Forget Your Spare (nsxtcjr)
Good info. Thanks for the reminder, especially since it has been getting pretty nippy here the last few nights!!
Old Sep 23, 2002 | 12:29 PM
B2FiNiTY's Avatar
Maybe I should check my spare...I never check it.
Old Sep 23, 2002 | 01:43 PM
ZygSpeed's Avatar
Default Re: Winter Air Pressures, Don't Forget Your Spare (ExOdy)
I was just thinking about the seasonal air temp/pressure changes, as I was scooting along and playing with lift throttle oversteer (more than usual, empty tank) on the way home from work today!
[Modified by Zygspeed, 5:44 PM 9/23/2002]
Old Sep 23, 2002 | 01:46 PM
1GreyTeg's Avatar
I check mine every time I drive it...
Spare We don't need no stinkin spare... "famous last words"
A.
Old Sep 23, 2002 | 02:17 PM
nsxtcjr's Avatar
New User
Default Re: Winter Air Pressures, Don't Forget Your Spare (1GreyTeg)
I leave my spare at home when I'm driving to the track with four (or more) track tires/wheels inside the car.
Otherwise, I bring my spare along for the ride.
Old Sep 23, 2002 | 02:48 PM
1GreyTeg's Avatar
I know, I know I just had to add that... Tongue in cheek all the way.
Thanks for the informative reminder.
A.
PS I'm not even driving her from the first snow till spring this winter. Lucky me... or maybe not.
PPS the spare reminder is VERY important. I know because I changed my wifes spare on when she got a flat last month and don'tcha know it was 45 PSI instead of the printed 60. Had to go air it up Before I was able to get the flat repaired. totally agreed witht eh spare thing man.
[Modified by 1GreyTeg, 3:51 PM 9/23/2002]
[Modified by 1GreyTeg, 3:53 PM 9/23/2002]
Old Sep 23, 2002 | 02:54 PM
Tweakmeister's Avatar
Winter....no more bikini's....(outdoor's anyway).
CAI = more POWAR!!!
Old Sep 23, 2002 | 03:40 PM
Paste's Avatar
Loved
Default Re: Winter Air Pressures, Don't Forget Your Spare (Tweakmeister)
Yeah well the winter here is about 70 degrees. I don't even need snow tires
[Modified by paste, 5:40 PM 9/23/2002]
Old Sep 23, 2002 | 03:47 PM
Default Re: Winter Air Pressures, Don't Forget Your Spare (paste)
damn Chris ... damn
Tweakie - who's hand gets stuck to the Spoon **** when it goes below freezing.
Old Sep 23, 2002 | 04:20 PM
nsxtcjr's Avatar
New User
I'm sure you know to put air in the tires in spring.
I find that on my car that sits all winter, it loses about 5 psi in each tire just due to time.
Built CRX
Honda Civic (2006 - 2015)
10
Jan 9, 2008 10:04 AM
a2dadamm
38
Apr 24, 2007 09:45 PM
nsxtasy
Sep 14, 2005 04:50 PM
hotsuma23
Oct 11, 2004 03:29 PM
TypeR01-424
Nov 13, 2001 11:01 PM
