help me out some one
Old Dec 22, 2010 | 12:37 PM
dootery's Avatar
Icon2 help me out some one
no power to obd diagnostic port on 97 accord f22b
Old Dec 22, 2010 | 01:01 PM
sgraham01's Avatar
Default Re: help me out some one
that should be coming off a fuse directly from the battery. if you have a good ground and no power, it may have blown a fuse or you have an open circuit in the power wire.
find the circuit diagram to see which fuse it runs off of or check all fuses to find the blown one.
if you need to hook up a scan tool, you can run a fused wire directly from the battery to the back of the obd port (backprobe it) and hook up the scanner, or run that same wire from the battery and all other wires to the scanner from the port with paper clips and jumper wires in the obd port.
253 Built
82
Aug 31, 2011 10:39 PM
niceprelude
Dec 24, 2008 07:13 PM
Skeletor
Audio / Security / Video
Sep 6, 2007 09:50 AM
9500redline
Oct 28, 2005 06:25 PM
Full Race A6
Jan 30, 2004 08:38 AM
