Suspension & Brakes Theory, alignment, spring rates....
spring rate for del sol
Old Dec 21, 2010 | 02:08 PM
sshh's Avatar
Default spring rate for del sol
just ordered GC's coilover for my 93 h22 turbo del sol,
i will use it 50% for drag and 30% for race track and 20% for cursing.
After some advices the rate ordered are front 550 and rear 450.
from your experience, is it OK? or should i change it?
Thanks
Old Dec 21, 2010 | 04:31 PM
MonkeyMagic's Avatar
Default Re: spring rate for del sol
20% cursing? you need anger management.
sorry i don't have any advice for del sol spring rates.
Old Dec 21, 2010 | 08:39 PM
98civdx's Avatar
Master Detailer
They will fine, but I would go a bit lower in front.
More like 380f 450r
Old Dec 22, 2010 | 11:06 AM
sshh's Avatar
More like 380f 450r
Why?
Old Dec 22, 2010 | 12:03 PM
98civdx's Avatar
Master Detailer
It's just my personal perference, I perfer oversteer over understeer....
Do you already have sway bars?
Old Dec 22, 2010 | 01:35 PM
sshh's Avatar
i know i should have ones with this rates,
I am thinking on change it to 480f and 550r because i will drag it more the DD it. and on track it would be more handled.
What do you think?
I think i have some time to change it.
Thanks
Old Dec 22, 2010 | 03:17 PM
98civdx's Avatar
Master Detailer
That would be good, you could also swap the 550lbs in the front if it is to much in rear.
Are you runing sway bars?
Also, what shocks will you be runing?
Old Dec 22, 2010 | 10:19 PM
sshh's Avatar
OK, deal closed on 500f and 550r.
no sway bars.
will use it on yellow koni.
Thanks
Old Dec 23, 2010 | 08:30 AM
98civdx's Avatar
Master Detailer
Yep, glad to see you aren't using stock shocks lol
Old Dec 23, 2010 | 10:07 AM
sshh's Avatar
Thanks!! for your help
7rrivera7
Suspension & Brakes
Mar 11, 2012 08:02 AM
docmanakos
Jun 3, 2004 05:21 PM
DMF
Dec 12, 2003 09:50 AM
