Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness Question: Snap-in vs Bolt-in
Old Sep 23, 2002 | 10:56 AM
JeffS's Avatar
Default Harness Question: Snap-in vs Bolt-in
Is there a safety difference between the snap-in and bolt-in type belt mounts?
I'm looking to permanently mount harnesses in my car. The shoulder straps will be wrap-around. I cannot think of a reason to ever take them out, other than to permanently remove them. I'm looking at the ends though, and the snap-in just looks like it could offer greater installation options. Having never done this before, it's highly plausible that I just don't know what I'm talking about.
The price difference is negligible, so my only concern is if either of these would be considered less-safe.
Old Sep 23, 2002 | 11:06 AM
DTAYLOR's Avatar
New User
Default Re: Harness Question: Snap-in vs Bolt-in (JeffS)
Jeff, I have the snap in ones and they are great. I think that if they sell them like that then it should be ok. Also they will sit at the correct angle when you pull them or adjust your seat.
Old Sep 23, 2002 | 11:14 AM
Geezer's Avatar
I replaced the OEM seat belt mounting bolts with the appropriate eye-bolts and snap my lap belt in, with the shoulder belts on harness bar of my rollbar. No problems so far. Also no drilling holes in the car.
I believe that some racing organizations ask you to put a cotter pin through the snap (a hole is provided) to lock it closed and make doubly sure that there is no chance of something unsnapping it.
Old Sep 23, 2002 | 11:17 AM
r2x's Avatar
r2x
Default Re: Harness Question: Snap-in vs Bolt-in (DTAYLOR)
For the most part, this is probably true, but we'll have someone believing that "Monkey Barz" are OK since they "sell them" so they must be safe.
I have the snap in lap belts, the bolt in sub strap, and the shoulder harnesses around the harness bar.
Old Sep 23, 2002 | 11:29 AM
bulldog_RS20's Avatar
Default Re: Harness Question: Snap-in vs Bolt-in (Geezer)
This is absolutely correct. Don't run without the cotter pins in.
Regardless of which you decide on, get big backing plates if your going through the body of the car...
Old Mar 28, 2005 | 12:10 PM
Fuster_Cluck's Avatar
Default Re: Harness Question: Snap-in vs Bolt-in (bulldog_RS20)
How exactly do you mount the snap-in harnesses?
I'm looking to get these Sparco harnesses --> HERE
Car = EK hatch
Thanks!
Old Apr 13, 2005 | 11:37 AM
daigo's Avatar
Jeff,
Look to make sure they meet the latest FIA/SFI ratings. Their testing standards are amongst the highest in the safety industry. These go beyond personel opinions most people have.
Cheers
Old Apr 13, 2005 | 01:33 PM
Knestis's Avatar
Default Re: Harness Question: Snap-in vs Bolt-in (daigo)
Snap-in ends allow some play for alignment changes (e.g., when belts are adjusted or seats moved). They are generally easist to work out and are certainly good if the proper eyebolts are used, and backed up if they are in drilled holes.
K
Old Apr 13, 2005 | 02:14 PM
johng's Avatar
Default Re: Harness Question: Snap-in vs Bolt-in (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
I'm looking to get these Sparco harnesses --&gt; HERE
Those are 2" belts. You may want to reconsider and purchase 3" belts with a sub if you're spending time on track at speed.
$.02
(If you're just autocrossing, disregard that)
Old Apr 13, 2005 | 02:17 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">How exactly do you mount the snap-in harnesses? </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=517099
http://www.sandmracing.com/ssabelt.html
There is also a good article in last month's GRM issue...
blackdc5
12
Nov 25, 2007 07:24 AM
01-0720
Jun 20, 2007 11:52 AM
EG TYPE-R
Jan 22, 2004 05:16 PM
MooreBoost
Apr 16, 2003 02:34 PM
jasonb
May 13, 2002 10:29 AM
