fs: b16 Head, Holset turbo, PR-3 crank. PA, 15211
Ok guys, decided to part out most of my setup. You may have seen the shortblock already and this thread is for the other stuff, head, turbo, spare good b16a crank. Make offers on whatever you like, Ill work with you and travel to meet up/deliver. (pics will be up by end of week.)
1. B16a cylinder head, gsr intake cam, b16 exhaust (i think, has one groove on it, might be b16), comes with intake manifold,. complete internally., I will assembly it again. no valve cover, or throttly body, does come with vtec sol.
2. B16a crank, good condition, came from stock running motor, that had busted ring lands from mild boosted setup. 120shipped.
3. Holset HE351Ve turbo, dont know exact specs, but has 5k miles on it, unsure condition...make offer. Came off 09 dodge cummins diesel, so whatever turbo comes stock on that, this is what it is. Has some resistance to spinning by hand, some oil and debri found in the turbine, blades are perfect, maybe just needs some oil flushed through. Was told worked perfect on stock truck, maybe running rich? Also, does the Variable Vein system effect this spinning? I just dont know. Update: Shaft spins A LOT better after putting oil in it.... should be fine.
Thanks., let me know.
3. Holset hy35 turbo, dont know exact specs, but has 5k miles on it, EXCELLENT condition...make offer. Came off 09 dodge cummins diesel, so whatever turbo comes stock on that, this is what it is. Looks like an hy35 to me.
i sent you this in a pm too with my number....
si0385.
Oct 12, 2006 05:36 PM
