Map Sensor Problem cb7 h22 swap
Old Dec 18, 2010 | 10:54 AM
brian8702's Avatar
Default Map Sensor Problem cb7 h22 swap
got a 92 honda accord with a h22a swap
Ok i had a cel for my map sensor.
i followed the stickys and rewired my map sensor from obd1 to obd2
well went to start it up and it wont stay running. but theres no cel's
i unplugged it and started it up then pluged it in. no cels and it stayed running but if i turned it off and tried starting it. it'll turn over but shuts right off and kinda back fires.
any idea's ?????
Old Dec 18, 2010 | 01:31 PM
GhostAccord's Avatar
Default Re: Map Sensor Problem cb7 h22 swap
You may have a wire or two mixed up! Reference your wiring diagrams and make sure everything is wired in the right spot.
Old Dec 18, 2010 | 06:44 PM
90cb4door's Avatar
DId you cut the wires for the map or did you depin the 92 obd1 accord map plug and then repinned into the obd2 map sensor plug.
If you have cut the wires maybe 1 wire isnt connected or you swapped the wires in the wrong spot
97EKCRVtec
Aug 18, 2009 11:36 AM
88Hatchy
Jun 1, 2009 10:20 PM
mkcivic
Jun 14, 2007 10:35 AM
hondaeg8
Jun 22, 2005 03:03 PM
civicracer1993
Jan 13, 2004 09:13 AM
