Question about 5 lug spacer conversion
Old Dec 17, 2010 | 02:26 PM
highwhey's Avatar
Default Question about 5 lug spacer conversion
Anyone ever done the conversion? Basically it's a spacer that fits into your 4 lug setup and converts it to 5 lug. I'm being offered all 4 for 170...not very bad considering each pair is 130 online. Reason I ask is I'm buying some volk te 37's(16 inch) for 600...these are my fav wheels. I have an integra, 95 ls. I'm wanting to know more info before I go ahead and purchase them without knowing eveything...last thing i want to do is spend 170 and realize there's a huge fitment problem. thanks!
Old Dec 17, 2010 | 03:14 PM
MindBomber's Avatar
Default Re: Question about 5 lug spacer conversion
A quality set will run you around $350 new, there are a lot of lower quality sets available, but this is one part you do not want to skimp on. Theres a great thread about these somewhere, but I can't find it..
Old Dec 17, 2010 | 03:30 PM
TunerN00b's Avatar
Then be certain to add the size of the adapter into the offset of the wheel when trying to decide if they will still fit or not.
Adapters push the wheel's mounting point out from the car. You'll need a higher wheel offset to compensate. Unless you like the wheels sticking out past the fenders look.
Old Dec 17, 2010 | 06:30 PM
highwhey's Avatar
so since the spacers i'm looking to buy are around 50mm and the volks are 30ish mm, then it would stick out right? hmmm...i def do not like them to stick out.
Old Dec 17, 2010 | 10:12 PM
r.wright's Avatar
it would bring it down to roughly -20 mm offfset. just spend a lil more for the correct pcd or just settle for a wheel for less money.
Old Dec 18, 2010 | 07:07 AM
highwhey's Avatar
yeah...oh well. feels unsafe anyway. thanks guys. i;ll probably just get 4 lug itr replicas.
Old Dec 18, 2010 | 07:33 AM
Chef Andre's Avatar
HT's TOP CHEF
I used them with no problem to run a set of 4x114 Mugen M7's. It worked out because it was a 20mm spacer and the Mugens were +50 offset which made the car sit at +30mm offset.
I'd first figure out the exact offset of the wheels and the width of the spacer.
Delsol_Drew
Oct 15, 2014 08:00 PM
TheAngryGinger
May 24, 2011 06:06 PM
DC2_2
Jul 24, 2006 09:54 PM
Turbo_Teg
Sep 11, 2002 06:51 PM
