new GSR timeslips (5800' elevation)
Old Sep 23, 2002 | 08:52 AM
b18cya's Avatar
Default new GSR timeslips (5800' elevation)
just remember this is at 5800ft altitude
best: 16.373@85.40
Old Sep 23, 2002 | 09:07 AM
b18cya's Avatar
Default Re: new GSR timeslips (b18cya)
opinions?
tips on how to get a better 60' time?
Old Sep 23, 2002 | 09:31 AM
SoulSurfer's Avatar
What was tire pressure at?
Old Sep 23, 2002 | 09:51 AM
b18cya's Avatar
Default Re: new GSR timeslips (LSDelSol)
25psi on some yokohama radials. right now i just ahve some 14" steelies on
Old Sep 23, 2002 | 12:05 PM
flip1199's Avatar
What rpm are u launching at???
Old Sep 23, 2002 | 12:52 PM
b18cya's Avatar
Default Re: new GSR timeslips (flip1199)
the first 2 runs i launched at 4-4.5k
the third i launched at 5.5k
Old Sep 23, 2002 | 07:09 PM
JMX's Avatar
JMX
what is that put into sea level terms....even with that i dont think your running mid 15 sec ....when u could hit low 15sec in reality
Old Sep 23, 2002 | 07:22 PM
aznmc16's Avatar
Default Re: new GSR timeslips (jmx2323)
when the last yellow hits.. slip the clutch.. you'll be spinnin the tirse and by teh time green hits.. you'l be moving.
Old Sep 24, 2002 | 07:35 AM
SergEK's Avatar
Default Re: new GSR timeslips (aznmc16)
According to the NHRA correction chart 5500 ft is max
Your best run came at 15.32@91.73 (16.451) not bad but still some room for improvement. Buy some drag radials and you should see a 16.00 locally for you if not a 15.99 which at your elevation shouldnt be too bad.
Oh your correction factor for 5500 is .9315 for ET and 1.0731 for mph
You can use that standard to measure your progress against others.
Old Sep 24, 2002 | 01:38 PM
jdm8k's Avatar
Default Re: new GSR timeslips (SergEK)
Old Sep 24, 2002 | 10:15 PM
b_edson's Avatar
Default Re: new GSR timeslips (jdm8k)
Just curious, what happened with the R/T on the third run? Yeah, get some drag radials and just keep experimenting with the launching technique and you'll get those 60' times down.
Old Oct 2, 2002 | 10:39 PM
b18cya's Avatar
Default Re: new GSR timeslips (b_edson)
i forgot to update this thread.
i ran again on wednsday sept 25th and:
r/t .603
60' 2.361
330 6.648
1/4 15.774
mph 88.10
but this is with the interior stripped, cleaned air filter, & 22psi in the tires
anyone know what this would be at sea level.
i know rota slips are kinda played out, but for the price & weight, i cant find a better deal so i'm gonna get some. i think the wider tires will help my 60' times
[Modified by b18cya, 11:41 PM 10/2/2002]
Old Oct 7, 2002 | 08:27 AM
SergEK's Avatar
14.69@94.54
I left the correction factors you can use in the other post.
Nice trap speed.....still need more work on the launch though. some 2.0's will have you running 14.30's most likely
EJtypeR
Jun 21, 2005 11:00 AM
whteteg8901
Sep 19, 2004 04:46 PM
whteteg8901
Sep 18, 2004 04:32 PM
JiggyKooAndy
Jun 26, 2003 08:47 AM
TeamTooQuick
Jun 20, 2002 01:17 PM
