Honda 2001 accord power window problem
2001 honda accord power window problem
when I am inside the car I have no control of locking or unlocking doors all 4
also no control of the passenger and rear power windows
yes the switch seems to have no action
I have to pull up the driver side door lock to open the door
The remote does lock all doors but the lite doesn`t blink like it did before(parking lites)
the remote unlocks the driver door and the other doors but no lite comes on (blinks)
the power windows do work on their own switch but no with the driver master switch
Rick >>> rkmtt@yahoo.com
Common problem. Try resetting the multiplex...set the intermittent wiper ring to the middle position, turn the car on for 10 seconds and then turn off.
A search will also show the solution.
There's more than one; but, the multiplex causing your problems probably is the one in the driver's door. See TSB:
http://www.tegger.com/hondafaq/tsb/accord/x98-071e.pdf
But, did you try the reset procedure first on the wiper switch?
tormont
Dec 1, 2010 08:44 PM
vtec.dc2
Mar 28, 2010 11:13 PM
swminnesotan
Oct 7, 2004 07:05 AM
