Injectors blow out special
Delphi and bosch injectors machined to fit hondas each injector is flow tested as well.
High imp
BOSCH 24# INJECTORS
These Each: $
DELPHI 30# INJECTORS
Each: $
DELPHI 37# INJECTORS
Each: $41.65
DELPHI 50# INJECTORS
Each: $66.50
LOW IMP
55lb/hr Delphi - Set of 4: $
65lb.hr Delphi - Set of 4: $
75lb/hr Delphi - Set of 4 $
84lb/hr Delphi - Set of 4 $
95lb/hr Delphi - Set of 4 $
160lb/hr Bosch - Set of 4 $
[Modified by b18bturbo, 11:09 AM 9/23/2002]
[Modified by b18bturbo, 2:43 PM 9/25/2002]
High imp
BOSCH 24# INJECTORS
These Each: $
Each: $
Each: $41.65
Each: $66.50
LOW IMP
Got any deals on standard Bosch injectors? I'll need a set for the secondaries on my JG/Edelbrock manifold
Anything 42#+ saturated would be acceptable.
55lb/hr Delphi - Set of 4: $260.00 shipped
65lb.hr Delphi - Set of 4: $260.00 shipped
75lb/hr Delphi - Set of 4 $260.00
84lb/hr Delphi - Set of 4 $290.00
95lb/hr Delphi - Set of 4 $325.00
160lb/hr Bosch - Set of 4 $360.00
Can you give me a quick rundown on low impedence?? I think I am gonna be down for a set of the 65 or 75's....before the end of the year.
I never heard of Delphi, any idea where to obtain some info on them. How do they compare against RC, i see such a price difference between the 2 and im curious as to why it is so. If these work fine then what is it that makes RC so damn much.
I ran 450 cc DSM injectors but they would not fit in my STR fuel rail, only my stock rail...would I have any problems with the Delphi injectors in an STR rail??
correct me if i am wrong but isint Delphi a sensor/electromechanical device supplier for GM and other US automakers? They are equivalent to Nippon/Denso in Japan?
for Viren.
