MPG
Old Dec 15, 2010 | 02:02 PM
kevinm1981's Avatar
Default MPG
What are some ways I can increase my MPG. I have a 97 ex coupe with jdm b18c SIVTEC and am barely getting 25-26 mpg on the freeway and about 20-21 in the city. This mileage is while babying it and not revving past 6k.
Mod list on the motor:
jdm b18c
cold air intake
type R cams
98+ type R header
test pipe
custom piping
magnaflow muffler
full tuned
chipped p28 ecu 5.5 vtec no redline
butterflys removed
Old Dec 15, 2010 | 02:06 PM
Former User's Avatar
Default Re: MPG
What's your driving style?
When was your last tune up?
Have you checked the ignition timing?
Any CEL codes?
Old Dec 15, 2010 | 02:18 PM
kevinm1981's Avatar
Default Re: MPG
I hyper drive most of the time barely pressing the gas and shift at 3k. Occasionally vtec to redline, not that often though.
I changed the plugs.
Need to check the timing yeah.
No cel. Sometimes the light comes on but then goes away. Usually during the day and whens its warm it happens.
Old Dec 15, 2010 | 02:24 PM
Default Re: MPG
The plug wires, distributor cap, and rotor are also important parts of a tune up.
The next time the CEL turns on, pull the car over to the side and jump the service connector while leaving the engine running. This way you can recover the code.
Old Dec 15, 2010 | 02:34 PM
kevinm1981's Avatar
Default Re: MPG
Ok, plan on going with ngk plug wires, already got the v2 plugs. Thanks..
Old Dec 15, 2010 | 02:39 PM
92lxsleeper's Avatar
Default Re: MPG
24mpg isn't too bad for a b18c, but it all depends on your driving style. considering you have that motor, i can be safe to assume that you like to get on it some when you drive, which would account for the mileage.
i have a 92 hatch with a d15b7, retarded timing, and with conservative driving i can get 48mpg is my best, but normal driving with some getting on it, roots me around 35-38 mpg
Old Dec 15, 2010 | 03:09 PM
kevinm1981's Avatar
Default Re: MPG
my b18b powered integra gs got 40 mpg on the freeway...
Old Dec 15, 2010 | 03:47 PM
jerryegk24's Avatar
Default Re: MPG
Originally Posted by kevinm1981
What are some ways I can increase my MPG. I have a 97 ex coupe with jdm b18c and am barely getting 24mpg combined.
Is that from city or hwy? When freeway cruising how fast you're going 70mph etc...
Old Dec 15, 2010 | 03:55 PM
-__-'s Avatar
Default Re: MPG
you are getting fair gas mileage i say. also what kind of ECU are u running? and is it a JDM B18C type-r or SiR-G/GSR?
Old Dec 15, 2010 | 05:13 PM
kevinm1981's Avatar
Default Re: MPG
should be the sir g ecu. go 60 or 65 on the freeway. I just changed out my ebay header that was horribly dented for a jdm itr one. seems its getting a little better mpg now. Still need to reset the ECU. Doing that right now.
Old Dec 27, 2010 | 04:48 PM
kevinm1981's Avatar
Default Re: MPG
Reset the ecu and got a new filter on my cai. Still barely getting 25mpg. Fuccc...
Old Dec 27, 2010 | 05:00 PM
Project H's Avatar
Default Re: MPG
Retard timing ,tire pressure ,spark plug wires,spark plugs with correct gap,rotor and cap,synthetic oil
Old Dec 27, 2010 | 08:37 PM
sanchoem1's Avatar
Default Re: MPG
If the alignment is off that could possibly make a difference.
Old Dec 27, 2010 | 08:48 PM
kevinm1981's Avatar
Default Re: MPG
I think the reason is because my car was dyno tuned before i owned it and its probably running rich and timing is advanced.
Old Jan 29, 2011 | 12:18 PM
kevinm1981's Avatar
Default Re: MPG
changed the oil to full synthetic and its a little better now. Any more ideas? Still need new plug wires.
Old Jan 29, 2011 | 12:20 PM
grumblemarc's Avatar
The Grumpiest
Default Re: MPG
Get it retuned.
Old Jan 29, 2011 | 12:23 PM
kevinm1981's Avatar
Default Re: MPG
I will once i get some aftermarket parts on there. IM, TB, cam gears and some fuel parts.
Old Jan 29, 2011 | 12:27 PM
kevinm1981's Avatar
Default Re: MPG
I will get it tuned very conservatively because its my daily and MPG is just as important as going fast.
Old Jan 29, 2011 | 12:49 PM
SeanK325's Avatar
Default Re: MPG
It also depends WHERE you drive. In Los Angeles and the San Fernando Valley, I go through so much stop-and-go driving that I sometimes never get into 5th gear when on the way to work/school. I think that is one of the most underrated factors in MPG. I have a stock D16Y8 and get about 24 mpg in all city driving.
Old Jan 29, 2011 | 12:51 PM
kevinm1981's Avatar
Default Re: MPG
I get 25 on the freeway!!! Sucks. Then again I have close to double the hp you have.
Old Jan 29, 2011 | 12:56 PM
SeanK325's Avatar
Default Re: MPG
There's your kicker, lol. Well, I'll trade my gas mileage for your HP.
Old Jan 29, 2011 | 01:38 PM
kevinm1981's Avatar
Default Re: MPG
yeah lol. the swap is 2899 plus shipping still on hmotors
Old Jan 29, 2011 | 01:42 PM
SeanK325's Avatar
Default Re: MPG
No shipping for me. I'm about 20 mins from them.
Old Jan 29, 2011 | 01:47 PM
92civlude's Avatar
Default Re: MPG
If you ever have the transmission out, Swap out 5th gear for an LS 5th. It has a longer ratio, youll get lower rpms in 5th. I did this to a GSR hatch/b16a2 trans at the same time an LSD was installed.
Old Jan 29, 2011 | 01:51 PM
kevinm1981's Avatar
Default Re: MPG
^ I plan on it. LSD and ls 5th. Best mods for a b18c IMO.
