bad steering wheel shake
when ever i get to 60 mph or over the steering wheel starts to shake alot also it does it sometimes when im sitting at a stop light for a while. could the tires be out of alinement or be unbalanced? is it ok to drive it like this? the car is a 1989 crx si
The shaking at 60 and at completely stopped are not related. If you mean shaking at slow speeds, then you have an out of round tire. A blister, flat spot or wheel not completely flush,
You should look into replacing the rack end bushing to fix the play in ur steering.
crxaddikt
Feb 10, 2004 08:55 AM
xhatchracerx
30
May 13, 2003 05:42 PM
