engine rebuild check list
Old Dec 15, 2010 | 07:37 AM
KINGVEM^^ED6's Avatar
Default engine rebuild check list
my stock b1 is getting close to dieing after 265xxx miles
so i picked up a b2 from my buddy and i am gonna throw it in my hatch
im at work making a list of everything i need and iv looked at a few sites to see if i
can get a list but i cant find anything
so im looking to see if someone has or can write up a list of all the **** i am gonnna need
thanks
Old Dec 15, 2010 | 07:57 AM
stackedhouse's Avatar
Default Re: engine rebuild check list
What are you trying to rebuild it for? What's wrong with it now? Be more specific?
Old Dec 15, 2010 | 08:59 AM
radex7's Avatar
^ That is a very good question I should have asked myself before getting into my rebuild project. I have been at it for like a year now... Not planning, not doing my research, and poor judgment totally kicked my... and wallet. In addition to stackedhouse's question consider your finances and time line. And DO NO RUSH WITH TOOLS TO TAKE IT ALL APART, you might regret it, like I did. Hell, I just noticed your post count, you might have been here for a while so you did not need all of that above. I think that the checklist is a great idea and I will try to contribute something later this evening.
Old Dec 15, 2010 | 10:50 AM
im rebuilding the whole motor bottom end and all stock specs
its for daily driving im gonna be moving to seattle so i wana get this done before then
i have all the tools iv just never done it
any help would be great
Old Dec 15, 2010 | 10:56 AM
also my buddy werks at autozone so 20 percent offannd other parts are plenntyfull in socal :p
well first you need to make sure that your cylinder walls are in good shape, no cracks or scores.. if there in good shape a diy hone is the route i would go there cheap and easy.. then of course new rings and seals check all your rod bearings and pistons rods etc make sure everything is in good working order before doing anything.. then replace what is needed re use what you can and put it back together.. but you might as well bore it out a little and get p29 integra pistons for a little higher compression
Old Dec 15, 2010 | 11:00 AM
FSRslug's Avatar
I am starting to assemble one of my Z6 engines this weekend. I made up a list of everything I needed as far as parts/machine work/tools, but its not on my work computer. I'll post up what I came up with later tonight.
Old Dec 15, 2010 | 11:09 AM
xXxRed FoxXx's Avatar
For a long block:
Gasket Kit
My suggestion
http://fjdistributors.com/product_in...roducts_id=256
Piston rings
Bearings
Thrust Washers
Timing belt
Timing belt tensioner
Oil Pick Up
Oil Pump
Water Pump
Keep in mind the routine maintenance items they can become costly. Cause you have to break in the engine afterwards.
Oil
Oil filter
Of course you can reuse your coolant, I suggest a flush after the engine starts.
*The condition your engine is in, will determine the machine work needed.*
If your Ignition items are okay now just look them over...
Sparkplugs
Wires
Cap and rotor
Everything here is just a suggestion, you may not require all of this and you may need more.
Old Dec 15, 2010 | 01:33 PM
well it was running my homie just pulled it out for b power
i want something i can take up there for two years and just have to worry
about oil changes and annual fluid flush
i got the pistons already with all rings and a nardi rep wheel for 50 bux
i dont wana buy a gasket set becuz im gonna get a oem head gasket
the things i wana know are were it say misc gaskets
thanks for all the help i am gonna try and pick some things up this weekend
also i will be getting a fresh valve job with hot tank for 80 bux
Old Dec 15, 2010 | 01:34 PM
thanks fox what else i would like to know is were you say i may require more i want to
know everything not just depending on my motor i wana know whats needed to rebuild it
Old Dec 15, 2010 | 04:13 PM
Why wouldn't you just get a full gasket set?
Old Dec 15, 2010 | 04:35 PM
idk
**** mite change my buddy said hell sell me his fully rebuilt y7 for 400
anyone done that swap before
what would i need to do it in my dpfi hatch
Old Dec 15, 2010 | 07:02 PM
FSRslug's Avatar
A full gasket set can be had for about $150. If it comes with a MLS head gasket, its probably OK to use instead of OEM. If you are taking the time to rebuild the motor you really should not re-use gaskets.
Old Dec 15, 2010 | 08:13 PM
Originally Posted by KINGVEM^^ED6
...what else i would like to know is were you say i may require more i want to
Checkout a Haynes manual, it will have the necessary tools for a complete overhaul. You wont need all of them and you could find some good alternatives instead of paying for some of these one time use tools.
Check youtube on the proper use for most and some ways to get around buying most of them. BE CAREFUL when choosing to cut corners. *AND TRY TO BE SAFE.* It will cost less in the long run.
Really your best bet to learning rebuilding is to have formal schooling. But if your really interested in it as a hobby, your only gonna be limited by your desire to learn.
I recommend checking out Dseries...org. Theres some impressive builds there.
Old Dec 15, 2010 | 08:29 PM
idk
Easy if you wanna keep it OBD0.. Do an MPFI swap.. Ive never done one but the write ups around here sound pretty good.
Then swap longblocks, keep everything from your MPFI manifold, dizzy and alternator.
Add some wire to your harness for your fan switch, on the y7 its on the thermostat housing, not on the back of the block.
Mine went by easy but I already had MPFI.
Old Dec 15, 2010 | 10:59 PM
Clipsed's Avatar
Vem, if you get the y7, lmk, I can wire it up for you obd-0 or obd-1, no point to go obd-2
Old Dec 16, 2010 | 01:27 AM
yeah i know not to reuse gaskets and thanks man ur the one i had in mind.....well see this weekend what happens im on the fence about this uggggh
Old Dec 16, 2010 | 05:26 AM
CivicxTree754's Avatar
Photogenic
Loved
Get some baggies and label everything you take apart and also keep similar bolts within the bag.
Nothing sucks more to think a bolt goes somewhere else n F* ish up! lol
Old Dec 16, 2010 | 05:52 PM
radex7's Avatar
Food for thought:
Gasket set: $80 http://fjdistributors.com/product_in...roducts_id=256
OEM head gasket (Y8-for compression and durability): $60
Bearings (assuming OEM): $180 http://www.hondaautomotiveparts.com/...artsSearch.jsp
Waterpump kit with tensioner and a belt: $60
Oil pump if needed: $40
ARP head studs: $100
Shop fee for tanking, decking and honing: $150
Coolant: $10
Oil, you need twice as much as you will be dumping it after break in period: $60
2 oil filtes: WIX, NAPA-Gold, Mobil-1: $20
$~700, still not head work included.
These of course are the rough prices and shooting for better bang for the buck, you might save the money by going through ebay, but you don't want gaskets from there if it is not OEM or at least Fel-Pro. Set of ACL bearings for both Main and Rods
might be only $70, but you do want does near-perfect oil clearances...
I say if your buddy's engine is already put together, broken in, and has some quality parts put into it, Clipsed can get you wired and converted for hopefully affordable price, don't bother with rebuilding B2 as you would still end up with 90HP.
Old Dec 16, 2010 | 05:55 PM
Clipsed's Avatar
Of course I'm affordable!!! Plus I don't think any of the big name wiring guys offer discount to those in the military, which I do, and they talk about mil spec this, mil spec that lolz
Old Dec 16, 2010 | 07:09 PM
gaskets 60
oil pump 85
water pump 20
oem hg 40
bearings 20 from buddy
pistons rings already purchased 20
valve job 85
hone will be done by me /grandfather inlaw :p
block will be checked and tanked
micropolish 30
plugs wires coolant &two oil changes 70
anything else?
Old Dec 16, 2010 | 07:10 PM
400......Tops and im not buildibg for hp im dding this car for the time i will be in seattle
Old Dec 16, 2010 | 07:16 PM
BiG ChOr!Zo's Avatar
why not just spend that money and get yourself a low mileage engine from a jdm engine importer...!!!
Old Dec 16, 2010 | 08:00 PM
civic nation's Avatar
Honestly you should just throw in a newer motor .
Old Dec 16, 2010 | 08:36 PM
Clipsed's Avatar
He asked for info on rebuilding his motor not where to get a used one. Reading owns some of you.
