Full 2004 K20A2 swap plus much more
im parting out my civic due to lack of interest. Ive had this motor in my car since last april, and it runs like an absolute champ. I put it in the right way without cutting any corners and the swap shows. NO oil burning, NO transmission grinds or issues at all. The motor is still in the car 100% drivable if you are interested. For the $3200 here is what all is included:
-2004 k20a2 motor and trans very very clean apx 55k miles max! no grease or oil at all!
-black powder coated valve cover, black dipstick, and black coil cover
-RBC intake manifold installed and stock one included as well
-ep3 idler pulley with new napa belt
-k24 steel oil pan
-karcepts coolant temp adapter for upper radiator neck
-shifter cables, box, and karcepts adapter
-golden eagle fuel rail with black -6an male fittings
-karcepts upper rad hose and gsr lower
-gsr throttle cable and matching rsx bracket that i made work
-02-04 wire harness with a mild tuck and the charge harness is wrapped into it as well
here are some pics before the swap, please forgive me not having my user name in these pics as they are old.
Im looking to sell my swap first, because if i cant get rid of it, then im just going to keep it for a while. As long as i can get some interest shown im going to be doing a full motor and car part out. Here are some items i have pics of:
Kpro - Sold!
Sparkks conversion harness for 96-98 ek - $150
Hasport ekk2 mounts like new - $400
Fuel lab regulator and the fuel lines to run an oem filter/return - $200
DSS pasenger axle and oem base drivers side axle. Work perfect - $100 pic to come
ASR subframe brace and asr sway combo - $320
Function7 LCAs - $160
Custom lower console wideband and keyed switch. The wideband is an NGK AFX and will come with the sensor. The keylock switch has a bracket made on the back side so it cannot be ripped out - $210
Personal neo grinta wheel, nrg slim hub, nrg black quick release, and locking hub. Has some wear on the wheel, nothing crazy - $250
Batl grounds swap header with 2 o2 bungs. Can include a plug if needed - $225
I have muchhh more i will be adding, but i really want the swap gone before i let anything go so i dont get stuck with a bare car and a k swap lol. feel free to pm me with anything you have questions about
-k24 steel oil pan
Kpro - Sold!
Not really interested in trades but feel free to throw some my way. I just took some pics so they will be up later on when I get home.
Thanks for the bump man. Hope all is well
Kpro says pending because its a prc and im supposed to be swapping with my friend for his prb since hes now running a 5 speed. price is 900 for kpro and 250 for the header
well if u dont swap it with him ill buy from you man...i can run that in a usdm ep3 tho right..lol cause i knoq prc is for a type R... and if you give me a combo price for the kpro and headers ill buy the headers too...I live in college park so I can meet you any to buy them
Ttt for a clean *** swap. Please tell all your friends! Six pack of your choice of beer included if my asking price is met, and you are of age!
bump for freshness glws
