Suspension & Brakes Theory, alignment, spring rates....
Warped rotors? (95 civic ex)
Old Dec 14, 2010 | 09:42 PM
xrsallday's Avatar
Default Warped rotors? (95 civic ex)
So a few months ago, my pads would squeak under braking, so i applied 'disc-brake-quiet' to the pads and all was good. but this past week, i noticed whenever i hit a bump or pothole in the road my rotor sounds like it's rubbing against something in a pulsating pattern every time the wheel turns. and when i hit the brake real quick it'll go away. could it be rubbing against the pad? or could i have a bad bearing making it wobble? i was going to change the pads and rotors soon but i hope it's not something more like a bearing or hub etc.
Old Dec 21, 2010 | 05:31 PM
xrsallday's Avatar
Default Re: Warped rotors? (95 civic ex)
bump please help.
Old Dec 26, 2010 | 08:32 PM
P-ville's Avatar
Kinda sounds like it could be a possible caliper issue, but that's my bench-mechanic theory. How did you apply the brake quiet? What kind of squeak is it, like when you have glazed rotors or higher pitched? The pulsation could also come from worn front end parts, try jacking the front of the car up off of the ground and feeling for play in the front end. Does it pull at all when you brake?
redrocket_ej1
Dec 9, 2009 04:18 PM
weez-0
Jun 4, 2009 01:11 PM
Danronian
Suspension & Brakes
Apr 16, 2008 07:30 PM
924doorEG
Aug 31, 2007 06:43 PM
B18CYAAA
Oct 1, 2003 08:18 PM
