04 cr-v vibration questions need help
OK its my gfs car its an 04 Cr v ex trim awd. suspension and steering is all tight. but when you maintain a speed of about 35 to 40. you very a thump thump then a vigorous vibration. until you let off or speed up. and it stops INSTANTLY when you do. its not a wheel or tire the tires are new and it did it before and after with no change. the vibration is very fast and vigorous. any ideas or if this is a common issue let me know. i was thinking a cv shaft or the drive shaft but i don't know how to check em. maybe a pilot bearing on the drive shaft i have no idea. any ideas would be great thanks
sounds like a drive shaft.... remove it and drive it in 2wd ... if sound is gone then you need a new one ... I ignored mine and it ended up breaking and it sucks to take the drive shaft off in the middle of the road.....
here is a U joint replacement for the Cr-Vs . I did mine but it was out of balance from being welded so I dropped it again and just drive in 2wd
http://www.rockforddriveline.com/replacem.htm
did you ever get this problem fixed? i am having the exact same issue with my wifes 04 awd crv. it is very strange. i did notice my right front axle leaking grease, just thought it had been old oil from changing the oil built up. anyhow id like to know..subscribed!
88accordcoupe
Classic Hondas
Oct 10, 2008 11:08 AM
