Race Ramps - Car Ramps, Show Ramps and Flatstoppers
Old Dec 14, 2010 | 05:02 PM
RedlineMotive's Avatar
Default Race Ramps - Car Ramps, Show Ramps and Flatstoppers
Race Ramps Show Ramps were designed seeing what people go through to raise their car up and place a mirror on the ground to display its underside. Show Ramps can be used to raise the front, back, or side of your car, or get two sets and raise up the entire car to make it stand out. Show Ramps are a great lightweight alternative (only 6 lbs. each) to jack stands, floor jacks, and wooden blocks. They reduce the risk of damaging your car, and they can be transported with no risk of sliding and denting your trunk.
Race Ramps Show Ramps (For Car Shows) RR-SR $125.10
These Race Ramps FlatStoppers are designed to help keep your tires from flat spotting during long periods of storage. Once the tires are set in the FlatStoppers (on a level surface), they will settle into the pad's concave depression. More of the bottom portion of the tire will be fully supported, thus dispersing the weight of the car more evenly onto the tire and helping to prevent any flattening. The Race Ramps FlatStoppers will not conduct heat or cold to your tires, despite changing floor temperatures. They will not damage your floor in any way and will not slide.
Race Ramps Flatstoppers RR-FS $233.10
These Race Ramps are ideal for low ground clearance vehicles with tires up to 10 in. wide. With an incline of only 10.75 degrees, they lift the car up 8 in. and hold up to 3,000 lbs. per set, while weighing only 10 lbs. per ramp.
Race Ramps 56 inch (Car Ramp) RR-56 $187.20
Race Ramps 67 Inch (Car Ramp) RR-XT $269.10
Race Ramps 67 Inch (Car Ramp 2 Piece) RR-XT-2 $307.80
Old Feb 22, 2012 | 07:31 PM
Default Re: Race Ramps - Car Ramps, Show Ramps and Flatstoppers
bump it up!
Old Feb 24, 2012 | 03:03 PM
bump it up for a sunny Friday
577HondaPrelude
Apr 27, 2010 07:02 AM
realride
May 19, 2009 12:15 AM
underpressure02
Mar 14, 2007 09:13 AM
FLATOUTRACING
11
Oct 6, 2004 01:06 PM
