2000 accord question
Got a 2000 2dr coupe, four lug, needs the driver side rear wheel hub assembly replaced, will the rear hub assembly from a four door work? also anyone know where I could find the oem part #'s, thankyou
Some are the same, some aren't. Type in the specific model you want to check and compare it to yours. Good luck. http://www.hondapartscheap.com/southbay/jsp/home.jsp
