Accord 91 Bat. light keeps ON after Key is removed
Dear Honda Tech,
Pls. guide me how to settle the issue with my Accord 91 EXi Battery Indicator Light remains ON even after key is removed & the Bat. Light turns OFF once ignition key is turned to ON Pos. even before engin start .
Battery weakened & died after few days since car remained parked I strained to know if ALT is not working ? Or matter is somewhere els, Can it be caused from mess up harnesses? or Ground connection ? since symptom found when I returned from Repair shop for change of Head Gasket. I want to know why such reverse indication is happened ? whether it is due to Harnesses mess-Up or bad wiring by the Mechanic? or ALT is bad? how to check?, I checked ground connections they looks OK. what else should I do to remedy the case? appreciated your guides.
S. Parsapour
parsapours@aol.com
Best regards,
Saeid Parsapour[/COLOR]
S. Parsapour
parsapours@aol.com
Best regards,
madsnave
Sep 22, 2005 09:41 PM
