whats wrong with this setup ?
Old Dec 13, 2010 | 05:56 PM
hello1320's Avatar
Default whats wrong with this setup ?
B series - 13-1 compression
84x89
Eagle rods/ weisco pistons
GSR head - just a line of sight port job....nothing crazy...Head is also opened up to 84mm
Crower springs/retainers......supertech valves
Comp cams 57300's
Victor x manifold.........with a 65mm T/B
SSR street sweeper header
Fluidampr puller
MSD Digital 6
Type R 4.78 trans
Hondas S300
Runs Q16......Made 225 and 151.
Does this seem like normal power #s for this setup. My guess is the cams and/or the head
1 thing I can say for sure....its defently not the tuner.
What do you guys think ??? Also car was tuned with the iceman headlight scoop on
Old Dec 13, 2010 | 06:09 PM
jdmcivic2fast's Avatar
Default Re: whats wrong with this setup ?
seems like the head is holding it back, with the power its putting out seems like the head is flowing like a stock head.
Old Dec 13, 2010 | 06:23 PM
93egSLEEPER's Avatar
84x89
Comp cams 57300's
Fluidampr puller
MSD Digital 6
Type R 4.78 trans
Hondas S300
I just looked up the specs of those cams and they dont look like bad cams, they should still make good power. I would get a larger TB and portmatch, 68-70mm. What kind of air intake/exhaust is on it? It does seem like the numbers are a bit low for the setup, and I blame it on an obstruction of airflow.
Old Dec 13, 2010 | 06:34 PM
b20vtech's Avatar
The head needs work, it flows "kinda" like stock. A stock gsr head flows around 255cfm @ .500 lift according to ALANIZ chart after converting the 153.14cfm @ 10" of water to 28" water.
your GSR head flows about 259cfm @ .500 lift 28" water
259cfm x .256= 66.304 x 4 = 265.216 HP
265.216HP x .15% = 39.7824
265.216HP - 39.7824 = 225.4336whp
note that this is only a rough estimation
hope this helps out!
Old Dec 13, 2010 | 07:05 PM
hello1320's Avatar
Thanks a lot guys.... Iam gonna have a head professionally ported.
Hoping to make 260. I've got pro 3s but gonna wait on those to c if the head will make the power....
Old Dec 13, 2010 | 07:35 PM
civic cx's Avatar
so what your saying is the power is not there because of the head flow...
Old Dec 13, 2010 | 07:54 PM
b20vtech's Avatar
yes, according to the calculations
a stock head flows about 255cfm @ .500 lift and has a potential power of 220-223whp
Old Dec 13, 2010 | 07:58 PM
hello1320's Avatar
I was leaning towards the cams...
Option 1...... slap the pro3s in
Option 2 ..... keep everything the same and just have the head ported
Option 3 ..... pro 3s with the ported head
Old Dec 13, 2010 | 08:08 PM
b20vtech's Avatar
obviously option 3, but im sure u will see a good amount of power from a good ported head.
Old Dec 13, 2010 | 08:22 PM
hello1320's Avatar
Iam gonna do the head for now......any suggestions ?
Old Dec 13, 2010 | 08:32 PM
d112crzy's Avatar
I'd personally try the cams first. It just makes more sense to me. Whichever way you choose, the head should be ported in a build of this caliber.
But a dyno sheet would help narrow down the problem.
Old Dec 13, 2010 | 08:58 PM
Professor15's Avatar
Why don't u take it to the track and see what it traps. You see alot of 220-250whp cars that barely break 110mph for w.e. Reason. Yet other cars Have awesome trap speeds for the amount whp they produce
Old Dec 13, 2010 | 09:24 PM
hello1320's Avatar
Its ran the 1/8
1.64 60 ft
4.96 330 ft
7.67@88
94 H/B
2190 w/driver
Best pass so far.....its not my car but I do all the work... I'll post some pics tomorrow...the car is beautiful.
Old Dec 13, 2010 | 09:33 PM
hello1320's Avatar
I'll post it tomorrow for u guys..... Iam gonna have to pull the motor to install the cams...we've got till late February till the start of the season...
Old Dec 14, 2010 | 06:45 AM
b20vtech's Avatar
Skunk2 pro3 Intake dur/lift 277/13.0, Exhaust duration/lift 284/12.4
Comp cam 57300 Intake dur/lift 290/12.9, Exhaust dur/lift 296/11.9
Not sure how much gain you'll see @ peak Whp between the 2 cams.
Old Dec 14, 2010 | 08:25 AM
d112crzy's Avatar
Theres a LOT more to cams than duration/lift numbers.
Old Dec 14, 2010 | 08:47 AM
b20vtech's Avatar
of course, these are just basic principle of camshafts. to the OP, start with what your budget allows you to do, but imo u cannot go wrong with proper head work!
Old Dec 14, 2010 | 09:42 AM
hello1320's Avatar
RLZ head in the works soon
Old Dec 14, 2010 | 09:50 AM
b20vtech's Avatar
yes u are in the right hands!
tempsohc
69
Oct 31, 2023 02:52 PM
b18sihatch
Jun 16, 2006 09:59 AM
JDM00SI
Aug 29, 2005 09:11 AM
