HELP CONNNECTING o2 SENSOR - CEL CODES
Old Dec 13, 2010 | 03:35 PM
BlackCivicEX's Avatar
Post HELP CONNNECTING o2 SENSOR - CEL CODES
My car is in limp mode and need to install the o2 sensor off my integra parts car that i got the 98 gsr motor from.
Need to know how and where to install the o2 sensor into my EG.
Have the p72 comp.
QUESTION#2 - Can i attach wires to after cat plug and extend wires.
And or do i need to switch the secondary plug into the cat and add wires to go into the secondary..
also have CEL CODES
1. 54 - CKF - crank fluctuation sensor
2. 65 - Secondary oxygen sensor heater wire (black wires)
3. 3 - MAP - manifold absolute pressure sensor
4. 22 -VTEC pressure valve
and do not have vtec plugged in yet- Might have map and crank sensor plugged in wrong.
Old Dec 14, 2010 | 10:48 AM
nicefighter80's Avatar
Default Re: HELP CONNNECTING o2 SENSOR - CEL CODES
the crank sensor will cause the limp mode, and can you re-word your 2nd question? since your using a obd2a/b ecu, then you will need a O2 sensor after the cat, just connect it to the factory wiring
yairsaenz83
30
Jan 5, 2008 01:26 PM
novtecnoboost
Feb 11, 2007 06:56 PM
PH3593A
Oct 13, 2004 10:14 AM
breathinez
Aug 18, 2004 09:20 AM
:jdmshmaydm:
Sep 19, 2002 04:57 AM
