New 18' rims and suspension lowering springs.
I would like to get a set of 18x8.5 wheels. What off set would i need to use for them to fit just right?
Also lowering springs? Can it be done right? I am looking at a small drop. May be 1.3-1.5 in the front and 1 inch in the back. Thank you for your help. Point me to the FAQs if i am asking stupid questions.
EDIT: it does not let me edit signature.... so here is my car: 2004 LX SEDAN. 70k miles.
8.5 would be fine, i run an 18x8.5 and im dropped 2.25F/1.75R with the Neuspeed Supercup Kit.
Offset im not to sure, do you wanna be flush, sunk, or just keep it stock-ishh....?
Sorry i do not know **** about suspension.
and once you drop it, get it aligned drive for like a month or 2 then go get your alignment checked. Sometimes the springs have to settle and ****
what would be a recommended drop? i am getting 18's with 40 profile tires so the tires will remain same size as compared to stock, only a larger rim.
get a rim that is 18x8.5 with +35 offset, 225/40/18 tires. You will be set, they will be flush but not super flush, you will be good with a moderate drop
RacerBoy
Sep 25, 2002 10:39 AM
