what d-series heads same as d16a6? stranded help!
Old Dec 13, 2010 | 09:37 AM
saveacivic's Avatar
Default what d-series heads same as d16a6? stranded help!
drove from north oregon to southern california. valves ticking for last 200 miles. finally busted the valves but got here. luck b/c i have the kids w/me. stock d16a6, cam and cam gear ok. what heads can i use to swap in. prob can get hands on a d15b7 but will it work w/my stock a6 cam/gear? thanks all
Old Dec 14, 2010 | 08:45 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: what d-series heads same as d16a6? stranded help!
It will work with pretty much any 88-95 SOHC non-VTEC 16v D-series head. They all come from the same casting. Do like you said, swap camshaft and camgear into the replacement head and you'll be good to go (provided you replace any other consumables and prep correctly for install). Good luck!
Old Dec 14, 2010 | 08:49 AM
efjones9's Avatar
it will work but if u have a d16xx block then u will need a b7 or b2 timing belt
Old Dec 14, 2010 | 08:52 AM
24TEN's Avatar
PHANTOM MENACE
^Are you sure about needing to switch timing belts?
Old Dec 14, 2010 | 08:54 AM
efjones9's Avatar
yea a6 has 104 teeth and iirc the d15s have 1 less
Old Dec 14, 2010 | 08:59 AM
24TEN's Avatar
PHANTOM MENACE
I guess my direct question would be, if the heads are the same and the A6 camshaft and camgear are being used, why would there be a necessity to change belts?
Old Dec 14, 2010 | 09:03 AM
jlk16188's Avatar
it is not necessary. If you were putting a different head on from a vtec motor you would. The b2/b1/b7 black all have different block heights than the a6 but the heads are all the exact same casting and size. Since you are using your stock a6 cam and gear, use your a6 belt. Now if you were swapping to a different cam, then you would need a different belt
Old Dec 14, 2010 | 09:11 AM
white90crxhf's Avatar
i just asked a very similar question a couple days ago and 24ten gave me the same great answer, the part number for the head of a d15b7 is the exact same part number for a d16a6.
Old Dec 14, 2010 | 09:22 AM
jlk16188's Avatar
Exactly! the head have the same casting number and everything. The only difference is the cam and spring stiffness. Now when buying used heads you have to make sure you are getting it from a reputable source and that the head wasnt decked a few times or milled. You may run into problems if you dont know roughly how much was taken off. You could end up buying a head that was "stock" buy had 0.050" milled off and end up causing you a lot of headaches in the end.
But unless you are changing cams and using a b2/b1/b7 cam and gear, then you would use a stock a6 belt with the a6 cam and gear.
Its very simple but there are a lot of people on here who like to make it more confusing
lorenzookc
Jun 13, 2011 06:31 PM
mass-hatch
20
Mar 22, 2010 02:28 AM
New Image
13
Feb 6, 2005 05:31 AM
USDM 4G VTEC
18
Jul 7, 2004 05:31 PM
