91 Crx Dx, mini me Issues
I've got a 91 Crx Dx that I've done a mini me (d15b7/z6) swap. Its now been sitting for a few months cause i don't know what the issue is. We had it running but it wouldn't move cause of a clutch issue. Fixed that BUT now the car won't run.
The car is getting fuel, plenty of oxygen. The distributor is getting hot BUT no spark. I did all the wiring myself(obd0-obd1, dpfi-mpfi).I've got a jumper harness connecting the obd0 converted harness to the p28 ecu. The car has been sitting at a shop and I just got done looking at the wiring under the carpet. There is a white wire with a red stripe that isn't connected to anything.
Anyone know what the &$#@ the issue is?
Pinout diagram:
http://www.ff-squad.com/technet/wiring.obd1.htm
On the D ECU plug, Check #9,#14,#18 pin all could be white/red. If your car is a 5 speed, then you dont need the #18 pin.
Pretty much just the basic b7/z6 mini me. The next thing the mechanic wants to check is the ecu (p28). I've had such a headache with this swap, it just feels my car will never run again
Anyone think of anything else?
If something is messed up with the wiring harness, is this what I should get? It doesn't say anything about the mpfi conversion but I'm guess it has it already?
http://rywire.com/store/8891-crxcivi...562b3dcd4a3793
Pinout diagram:
d16z6 distributor
How should i go about checking all the wires. I've got the obd0-obd1 jumper harness on wouldn't even image how to go about it
OK just checking on the distributor.. well read the pinout and check what should be there.. later on tonight ill sit down and send you a list of must checks...
Somebody help me!!! i have a 91 crx d15b2 that as i was taking off at a light my tach stopped working and my car started running bad. Im super confused and Its my only form of transportation to work and I need to get to work i have a kid i need to support... please help me guys
gnar kill
Mar 12, 2006 06:52 AM
