question about y8 with a6 head
Old Dec 13, 2010 | 06:53 AM
turboblack2door's Avatar
Default question about y8 with a6 head
my friend has a y8 block and his a6 took a dive but the head is still good. The oiling port on the block where the restricter is is bigger on the a6 block so he is not able to put the restricter in the y8 block to use a6 restrictor. Anyone ever made this work and how. Also does anyone know if the exhaust valves are the same on the y8 vs the a6 and i'm pretty sure the intake valves are bigger on the y8 but can anyone confirm this
Old Dec 14, 2010 | 08:41 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: question about y8 with a6 head
Look in the FAQ, I did a write up using a Z6 block with an A6 head and ran into the same issue. You'll see how I modified the oil control jet.
miguey310
Sep 6, 2013 05:59 AM
miguey310
Sep 5, 2013 11:36 PM
radster87
May 16, 2013 12:31 PM
dohdoh420
13
Oct 27, 2005 12:33 PM
