H22aEHhatch's JDM GS-R Build: Suggestions/Advice needed
Old Dec 12, 2010 | 09:25 PM
H22aEHhatch's Avatar
Default H22aEHhatch's JDM GS-R Build: Suggestions/Advice needed
For those with a jdm gsr, I've had my b18c in my hatch for a bit amd it's been stock. I'm looking to get 200-215 whp I know that te bolt on's help but I want your guys advice to maximize full power/potential on an all motor stock bottom end......thanks for the help
Old Dec 13, 2010 | 12:08 AM
racebum's Avatar
Default re: H22aEHhatch's JDM GS-R Build: Suggestions/Advice needed
in before flaming about unrealistic goals and using the search button
Old Dec 13, 2010 | 02:34 AM
95skunkedgsr's Avatar
lol... im to hung over to even flame this guy
Old Dec 13, 2010 | 05:52 AM
Madmood's Avatar
You wont reach those goals with the JDM GSR. But with the USDM its a possibility.
Old Dec 13, 2010 | 06:14 AM
corleone's Avatar
why not madmood? im about to get a jdm gsr...pls enlighten me on the difference...from usdm...thanks in advance
Old Dec 13, 2010 | 09:59 AM
Usdm 170hp 10.0:1 cr jdm 180 hp 10.6:1cr and the jdm ecu has a more aggressive map setting
Old Dec 23, 2010 | 12:43 PM
corleone's Avatar
thanks h22..thats interesting..i guess its okay for me since i wanna stay as stock as possible..but then again i do have prep for sudden urges to upgrade haha
Old Dec 23, 2010 | 08:47 PM
wreckeddc4's Avatar
2 layer head gasket and arp studs to bump compression, then cams, intake manifold, injectors and a tune. With the right header and exhaust you could get close to 200.
Its very difficult to hit 200 or more with anything less than that. A ported head would help alot if its in your budget.
Tune is the most important. Talk with whoever you plan on having tune it to see what parts they have made power with in a similar setup.
E85 if its available to you, might help gain a few hp, it works very well for me.
Old Dec 25, 2010 | 09:28 PM
Thanks a lot for the advice! I'm also thinking of going flat bottom valves and type r pistons.....in the future that is....with the extra CR I should be able to squeeze more power yea?
Old Dec 25, 2010 | 10:05 PM
UncleD's Avatar
Lock this thread and use the search function of this website. Read before making thread. You've already been given bad info, and will continue to recieve it. If you're bench racing, go back to jdmcarboy. The # 200 is the most played out/tired/beaten to death subject on the Honda forums. It's not "easy." It's expenssive. I don't care what your wonder ITR motor put down. Doesn't apply members. This is gonna turn into 95% of the rest of the threads do in the NA forum. People are gonna talk about how high there compression is and try to throw the biggest ****in camshaft they can in it, but complain and not want to spend $$ on a REAL header. They're gonna want to window shop and look at dyno graphs, but never once mention how quick they want to be at the track.
Honda Tech.
Old Sep 13, 2016 | 10:22 AM
christian2323's Avatar
Old Sep 13, 2016 | 10:25 AM
Hey i got a b18c1 gsr motor and i got some eagle rods and type r pistons for it and i got a skunk2 manafold but my plan is to make at least 215 hp but dont know wat to do next
Old Sep 22, 2016 | 11:46 AM
TheShodan's Avatar
Moderator
Default Re: H22aEHhatch's JDM GS-R Build: Suggestions/Advice needed
christian2323, you've been PM'd. This thread has run its course years ago..
Please follow the suggestions stated in the PM, and when you have specific questions, you can create your own thread. As for now this is now closed.
Justlearning95
Nov 5, 2016 06:39 PM
VTECcnIT
Feb 13, 2006 12:13 PM
saer
Aug 29, 2004 09:08 AM
RuffGsR
Jun 27, 2003 12:25 PM
NewbieGuy
Sep 2, 2001 10:42 AM
