b18c1 all motor cam advice
Old Dec 12, 2010 | 06:52 AM
hatchn1.9's Avatar
Default b18c1 all motor cam advice
Ok so i been researching for awhile now and i have my bottom end together now i need input on some good cams.Remember this is not my daily , but it will be streetable.Well heres the run down
.97 b18c1 gsr block 81.5mm
.rs machine 81.5mm p30 pistons
.stock rods (arp rod bolts)
.fully pnp head , valve job (arp head studs)
.skunk2 intake mani port matched to the head and tb and sand blasted the inside
.hytech try-y header
.450cc injectors
.ferrea 5000 titanium flat face valves
.omni 70mm tb
.b16 tranny (clutchmasters flywheel , act clutch)
My hp goal is 220+ .I just need some insight or advice on cams .I've looked at brian crower stage 3 , jun stage 2 , pro2 and 3 , blox type c which would be good.....
Old Dec 12, 2010 | 03:31 PM
NinJa_FLiP's Avatar
Default Re: b18c1 all motor cam advice
your going to be running around 11.6:1 compression right?? from your list, id go with the pro2's or maybe even the pro3's.. but then again, i may be biased because i usually stick with skunk2.. also, is there a reason u went with 450cc injectors? i think 310cc or even 370cc should be plenty..
Old Dec 12, 2010 | 05:38 PM
00Red_SiR's Avatar
All Motor Mentor
I don't think you'll reach your whp goal as it's very difficult to do in a 1.8L but your build looks pretty solid. Out of the cams you've listed, only the pro 2's or Blox C's would come close to the goal you want IMO.
Also it doesn't matter what size injectors he wants to run as long as he has a tuning system.
Old Dec 12, 2010 | 05:43 PM
hatchn1.9's Avatar
well im running the 450s cause i alredy have them and im deff getting tuned. There are builds out there with less head work than me making over 220 so i should have no problem....I no skunk2 are the way to go and i probly am but i was just seeing if anyone has run any of the others out there
Old Dec 12, 2010 | 05:44 PM
hatchn1.9's Avatar
c/r is going to be around 11:8 to 1
Old Dec 12, 2010 | 06:00 PM
slowcrx954's Avatar
check my thread,sould give you a good ideia.
Old Dec 12, 2010 | 06:07 PM
00Red_SiR's Avatar
All Motor Mentor
220whp on a dynojet? I would like to see them if you have any info/links to those builds.
Old Dec 13, 2010 | 06:06 AM
SLIM NOTHING's Avatar
pretty solid build with a budget. id say pro2s.. how are the omni tb's? i have skunk2 and its sticky and not liking it.
Old Dec 14, 2010 | 05:27 AM
hatchn1.9's Avatar
yea this is a budget build and the pro 2s are looking good as of now....the omni tb are really good ive had 4 of the on different builds .for the price there great
Old Dec 14, 2010 | 05:31 AM
hatchn1.9's Avatar
Ima try and get them...my boy put 205whp on a all motor ls non vtec 81.5mm block non sleeved fully built. I put down 216 on a 81mm fordged ls vtec with a mild built head...not ******* what you said but its posible
Old Dec 14, 2010 | 12:49 PM
00Red_SiR's Avatar
All Motor Mentor
for sure, I put down 207 whp on my 1.8L but those are just dyno numbers and not absolutes.
Old Dec 14, 2010 | 01:00 PM
93egSLEEPER's Avatar
Dyno numbers are "God" on HT I swear. Its a tuning tool. Let the track times do the talking
Old Dec 15, 2010 | 03:00 AM
hatchn1.9's Avatar
yea and im just doing a small build like this til next season when i get my sleeved block
Old Dec 15, 2010 | 03:01 AM
hatchn1.9's Avatar
very true
Old Dec 15, 2010 | 12:28 PM
LHTBill's Avatar
I'm loving my Skunk2 Tuner 2's
Old Dec 15, 2010 | 02:22 PM
hatchn1.9's Avatar
i cant make what i want on tuner series...but they are good cams i ran them in my h22 for a while
nate1723
Aug 25, 2013 08:53 PM
crazydominicanman
30
Jan 24, 2011 06:40 PM
rsa0905
Oct 14, 2010 12:48 PM
JDM809
Feb 10, 2010 10:25 PM
Irishweird00
13
Nov 1, 2003 08:34 AM
