engine bay seam crack, should i weld?
hi guys.
from some reason my subframe? spot welds and seamfiller(how do you call it?) started to crack,
i was thinking about removing all the seamfiller and seam weld the whole red and yellow lines on both sides of the car.
will it be a good idea? i dont care much if the front will get stiffer the main purpse of the car is drag.
here are the pics:
thanks
here are the pics:
thanks
Def not weld them completely, if you're going to weld them, then do it by the normal strengthening weld, with 1-2" of weld and then 1-2" of clear and so on and so on. Then paint and seam seal it, though unless its a race car and you're going to do the whole engine bay, I wouldnt bother, I'd just get some sealer and just seal the cracked OEM sealer, some OEM seam sealers crack, because they tried to save money at the factory.
