YS1 tranny, what year clutch do i use?
Old Dec 10, 2010 | 03:33 PM
808sleeperhatch's Avatar
Default YS1 tranny, what year clutch do i use?
i have a YS1 tranny on a b16, would an integra 90-91 clutch fit?
and has anyone ever ordered anything from VR speed factory?
thanks
Old Dec 10, 2010 | 03:37 PM
chefboyarluis's Avatar
Default Re: YS1 tranny, what year clutch do i use?
yea all b series clutches are the same the only difference are the throw out bearings the lil ear things on the throw out bearing that slide onto the fork are different
Old Dec 10, 2010 | 03:41 PM
ok right on, i was just asking because i heard the YS1 has different splines or something. thanks man
also do you know if the 91 civic si short ram intake fits under the hood with the b16?
Old Dec 10, 2010 | 04:35 PM
Deetz's Avatar
Crazy Honda Guy
So sad....miss information!!! and NO!
The YS1 will use any 92-01 B series clutch
The 90-91 uses a different pressure plate, so it's a different part number for the clutch kit
Old Dec 10, 2010 | 04:43 PM
RyanA's Avatar
Correct on the misinformation. 90-91 (and other single letter-1 cable transmissions) uses a small spline transmission, YS1 is large spline. Flywheel, clutch disc, pilot bearing, and pressure plate are interchangeable between large spline transmissions. The difference is cable uses a cable TOB and hydro uses a hydro TOB.
Old Dec 10, 2010 | 05:34 PM
94EG8's Avatar
Seagull Management
Different disc, pressure plate is probably the same.
Old Dec 10, 2010 | 10:03 PM
Deetz's Avatar
Crazy Honda Guy
ha ha, yup, had it backwards The disk! The mainshaft sizes are different, so different disk...man i was tired, now i know why i crashed a 7pm earlier, lol
Old Dec 11, 2010 | 04:41 AM
EFjoe91's Avatar
Thanks for the info. I do have a YS1 trans on my engine is it a true XSi engine. It does not have a LSD. I was told there is a way to put a helical into a NON lsd Gear box. IDK sounds crazy. I do want LSD performance. with out trying to find the same 1300 or $1400 Cable LSD.
Also i did do a brief search before on Ebay for b16a clutches and flywheel kits.
I seen things like XTD, exedy, and other brands. There are diffrent type kits for diffrent applications. I was intrested in like a 8lb flywheel and was wondering if something like that would be worth it. I did do some engine work, Have a CTR pulley, and would like to further lighten the rotating mass a little more. Wasnt sure if the thing would take away from any TQ measures. I expirenced a civic with alot of work and the guy emphasised his light weight rotating mass as the RPM climbed.
Old Dec 12, 2010 | 01:19 PM
****EN GREAT! anyone wanna buy a 90-91 integra exedy clutch?????
Old Dec 12, 2010 | 01:22 PM
thanks for the info, so i need a 92-01 integra clutch? its for a b16, with the YS1 tranny.
Old Dec 12, 2010 | 02:19 PM
RyanA's Avatar
You can use any clutch disc and pressure plate from a 92-01. You need to make sure to get the clutch release bearing for a 92-93 Integra as they are specific to the YS1.
Old Aug 14, 2012 | 10:28 AM
XxjohnnybravoxX's Avatar
Yes I have the same situation! I have a B16A motor w/ a YS1 tranny( don't ask me which YS1 it is Bc I don't know) and I need to buy a clutch for it! Do I jus buy a clutch kit for a 92-01 integra and then get a seperate clutch release bearing? Help
Old Aug 14, 2012 | 02:51 PM
ef92b's Avatar
this is what i use in all my three YS1 cable tranny's. comes with all you need. disc, p.plate, lightened flywheel, bearing, alignment tool.
http://www.clutchcityonline.com/ExedyExedyAcura.htm
P.N. 08-800A-HF01
jimmy o.
Jan 25, 2010 07:43 AM
B16Civic93
Apr 24, 2009 07:25 PM
b17 rolla
Jan 21, 2008 10:08 AM
R91Si
Mar 8, 2004 05:44 AM
