Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need help ASAP
Old Dec 10, 2010 | 03:27 PM
30psi_gst's Avatar
Default Need help ASAP
I have an H22a. Output shaft seal was leaking so i replaced it. Took it out and every other seal is slightly to small. Fits snug around the axle but inside the transmission its too loose. U can shift it side to side with it placed against the tranny. Tried every honda axle seal known to man. Most of the parts numbers are identical depending on brand. I even have a Honda part in it now. Still its to small. Its like putting a dime next to a penny. Very similar just about 1-2mm difference in diameter.
The one in the tranny fit fine (the old one being replaced that leaked), it was just tore and had a slight imperfection.
My question is, is there one i need to get from a certain manu. that is the right one. Because even the honda one is loose. Thats whats in it now and it leaks like crazy, drips even when car is off. Is there something i can use as like a stop leak to put around it?
Thanks for the help.
Old Dec 10, 2010 | 06:08 PM
94EG8's Avatar
Seagull Management
Default Re: Need help ASAP
If you can grab the number off the old seal see what it corresponds to.
Old Dec 10, 2010 | 06:54 PM
30psi_gst's Avatar
The old seal doesnt seem to have a part number on it anywhere.
Old Dec 11, 2010 | 12:33 PM
ion_four's Avatar
I think there is a different size seal for each side. I could be looking at the wrong one though.
OIL SEAL (40X58X8) (NOK) Right Side
OIL SEAL (35X56X8) (ARAI) Left Side?
Right Side Diagram:
http://www.hondaautomotiveparts.com/...ISSION+HOUSING
Left Side Diagram:
http://www.hondaautomotiveparts.com/...CLUTCH+HOUSING
BoostinEJ1
Jun 6, 2007 02:15 PM
mymeatb18"
Nov 27, 2006 02:41 PM
stp_vtec_boi
Aug 23, 2006 08:40 PM
Nicaraguense13
Mar 7, 2006 05:20 PM
88 rex
Aug 5, 2005 06:56 AM
