For Sale ::--built and turbo'd K20 Integra--:: For Sale
BIO:
12k OR BEST OFFER about 4000miles on everything except the shell
Ran a best of 11.7@118 mph in a 1/4 mile, while losing traction on 22'' slicks at 80% throttle.
The car put down 460whp on a mustang dyno, at 15psi of boost.
I have a ton of receipts and pictures throughout the motor building process. All you need is a race gas tune and you'll be at 600whp reliably
If interested email me at
Kampsi@yahoo.com
or PM me
I'm selling because i'm going a different route with my cars, "I'm going legit homez"
Shell:
94 Acura Integra (120k miles)
Championship White (1 yr old w/warranty)
2001 Front bumper and head lights
2001 Rear bumper
Type R Wing
Type R front lip
Type R optional side skirts (painted but, uninstalled)
S2k Antenna
8k HIDs slim ballast
sun-roof
Brake tucked
Wire tucked
Hasport Motor mounts
Motor:
K20z3 head
ARP headstuds
Skunk2 Valves
RBC intake manfold (port matched)
NGK Iridium plugs
Honda Oem K20z3 Headgasket
Hondata Intake manifold gasket
-Hot tanked, Intake and Exhaust port honed, valves checked and cleaned.
K20z1 cams
Type R valve cover
Painted Cast gray
K20a2 block
-Hot tanked and honed,
Polished and balanced crank to 10k rpm
ACL race series bearings
Eagle Rods
ARP rod bolts
JE Pistons (9:1 compression)
Earls modified Oil pump
Painted black
Transmission:
Stage 4 Competition Clutch
Brand new OEM flywheel
Synchromesh fluid
painted cast gray
Suspension:
Skunk2 coilovers (8k & 10k spring rate)
Skunk2 Camber kit (front & rear)
Traction bars
Type-R Strut bar
Type-R adjustable tie bar
Brembro blank rotors
Thermo quiet pads
Rims have been sold (comes with steelies)
Turbo set-up:
Precision's Billet Wheel 6265 .70/.63 ar
Tial 44mm wastegate (polished)
Tial 50mm Blow off valve (red)
Fab-this, Side mount Turbo manifold (T3)
Fab-this, dumb tube & down pipe
Fab-this, Intercooler piping (polished) (3in and 2.5in)
Treadstone vertical flow intercooler
Precision 1000cc injectors (oem resistor pack)
Golden Eagle Fuel rail
B&M fuel pressure gauge
Walbro 255lbh intake fuel pump
Aeromotive Fuel pressure regulator With fuel pressure gauge (12:1 rating)
Blox vacuum block
Hondata 3bar map sensor
Hondata boost by gear solenoid
FAL racing fans
Summit Racing oil catch can
Interior:
Kpro
S2k Gauge Cluster (with speedo healer)
Glowshift digital boost gauge (red)
Glowshift oil pressure & temperature gauge (blue)
AEM air/fuel ratio gauge
Greddy Turbo timer
Custom shift ****
Pioneer head-unit
APC racing seats (or stock ls leather)
GSR leather rear seats
Black interior
optional
Can come with everything
Hybrid racing a/c lines
Power steering
--open to trades
or trades + cash
Kampsi@yahoo.com
or PM me
Shell:
2001 Rear bumper
Type R Wing
Type R front lip
S2k Antenna
sun-roof
Brake tucked
Wire tucked
Motor:
K20z3 head
ARP headstuds
Skunk2 Valves
NGK Iridium plugs
K20z1 cams
Type R valve cover
Painted Cast gray
K20a2 block
Eagle Rods
ARP rod bolts
Painted black
Transmission:
Synchromesh fluid
painted cast gray
Suspension:
Traction bars
Type-R Strut bar
Thermo quiet pads
Turbo set-up:
Blox vacuum block
FAL racing fans
Interior:
Kpro
Greddy Turbo timer
Custom shift ****
Pioneer head-unit
Black interior
optional
Power steering
--open to trades
or trades + cash
