93' honda accord d4 light stays on
Old Dec 10, 2010 | 11:34 AM
Azteck's Avatar
Default 93' honda accord d4 light stays on
This is driving me nuts. I have a 93' honda accord sedan 10th anniversary edition and when I turn the key to the on position I have to wait for the d4 light to turn off before I can turn it on, I let it sit for a little bit then turn it off and try to turn it on but the d4 light will come on and stay on after that and the car will hard start. No flashing codes or anything. Parts I have already replaced include a leaky gasket seal and the alternator. Anybody know what could be wrong? I would appreciate all the help I can get.
Old Dec 23, 2010 | 09:00 AM
HiProfile's Avatar
Default Re: 93' honda accord d4 light stays on
I have seen a handful of ECU's go bad, and the light stays on constantly. Reset the ecu (pull it's connectors or battery power for a few minutes), and see what it does. Did you buy it like this? Did it just pop on by itself??
Old Dec 28, 2010 | 07:17 PM
A_Jax's Avatar
More than likely it's the TCM
I have a ecu and tcm out of a 94 accord if you're interested.
PM me
Old Feb 13, 2011 | 01:53 PM
Azteck's Avatar
I found out the problem. Took apart the AT Control Unit and there is a damaged resistor on the board. Thanks for the help guys.
Does anybody know if you have to program the replacement AT control unit? Or is it like plug and play?
Old Feb 25, 2011 | 03:48 PM
night's Avatar
you could just replace the resistors and caps.
but a replacement just plug it in.
Old Feb 26, 2011 | 04:21 AM
Azteck's Avatar
sweet thanks
Jeremy221
Audio / Security / Video
Mar 6, 2018 08:25 AM
speedracer28
Jul 14, 2010 10:38 PM
Sia
Oct 18, 2004 10:20 AM
