Transmission & Drivetrain Gearboxes, Differentials, Clutches
NEED HELP....
Old Dec 10, 2010 | 10:48 AM
ta1972's Avatar
Default NEED HELP....
Hi, I got this crx with a built b18c5 turbo from my ex shop partner,but can't seem to know what trans it's got in there. The label reads YS1-1042022. He told me it's a b16 for short gears,but i know there are different types of ys1's out there,so pleases help... Also my rpm works but the speedo don't work. the car currently has a stock 89 cable crx cluster on there. What do i have to do to make the speedo work? I looked at the transmission and it's got a vss sensor on there.I think this trans is originaly a cable type,but the installer installed a vss sensor for the quick install...Do i need to get a different cluster? If so what type fits best for this setup since this engine could handle up to 10k rpm??? I'm on a budget and would like to go the cheapest route...
Old Dec 11, 2010 | 02:44 PM
ta1972's Avatar
Default Re: NEED HELP....
Anyone shed some light here???
Old Dec 12, 2010 | 07:01 AM
stevenDAtegra's Avatar
It would probably be easiest to get a vss for a cable transmission. There will be a hole on top of them that the cable from the cluster slides into.
The transmission could be an ls or a ys1 from a GSR DA which have really similar gears to a b16 tranny. Do you know your rpm around 80 mph? If it's around 4500 then you have the gsr tranny
Jpummi
Jun 12, 2016 10:25 AM
PayMecracka
Apr 10, 2011 07:59 AM
ta1972
Dec 12, 2010 07:05 PM
ta1972
Dec 12, 2010 08:22 AM
crawfo661
12
Oct 22, 2009 04:04 PM
