NEED HELP....
Hi, I got this crx with a built b18c5 turbo from my ex shop partner,but can't seem to know what trans it's got in there. The label reads YS1-1042022. He told me it's a b16 for short gears,but i know there are different types of ys1's out there,so pleases help... Also my rpm works but the speedo don't work. the car currently has a stock 89 cable crx cluster on there. What do i have to do to make the speedo work? I looked at the transmission and it's got a vss sensor on there.I think this trans is originaly a cable type,but the installer installed a vss sensor for the quick install...Do i need to get a different cluster? If so what type fits best for this setup since this engine could handle up to 10k rpm??? I'm on a budget and would like to go the cheapest route...
In the DA integras they have a manual speedo reader and it bolts in place of the digital reader. and the mph cable from the same car. I know you can buy a new mph cable from napa fairly cheap too. You could get the JDM cluster but its going to be way more of a hassle and its going to cost almost 150$ more than the other way. Hope I helped.
Record your RPM drop from 2nd gear to third gear from a reasonably high RPM. Divide 2nd gear RPMs by 3rd gear RPMs. If your number is close to 1.44 then it's a B16, but if it's closer to 1.49, then it's LS.
I got those numbers from http://www.ff-squad.com/tech/temp/Bgears.htm by dividing the gear ratios of 2nd gear and 3rd. The ratios end up the same in the end whether you're comparing gear teeth or RPMs.
PayMecracka
Apr 10, 2011 07:59 AM
goldenhatch13
21
Nov 10, 2008 10:51 PM
