VSA switch?
Hi, i have a 2001 accord euro r (cl1 chassis) and i know for a fact that it has VSA because it has the yellow "!" on the dash and the yellow "VSA" on the dash aswell. I would like to turn it off as i know it limits the power to the wheels but i cant seem to find a switch or anything. Is my car year too old for a VSA switch? If so how would i go about turning it off? Any info is greatly appreciated.
Thanks
Thanks
2001 Accord V6 in the US and Canada supposedly had the TCS system and the on/off switch was located to the side of the driver's lower dash.
For newer Accords (e.g. 8th gen), the VSA on/off switch is also located on the side of driver's lower dash.
So check if you have such a switch at the similar location as shown in the image for the 2001 Accord V6.
Im not in the position at the moment to go to my car cause im at work but please note that my car is not USDM it is the JDM V4 euro r. Regardless i will check it when i can and keep you posted. Thanks for the info.
I am aware of that with your initial post. As there are not a lot of available resources for the euro spec. Accords here, I am posting where it is located on older and newer U.S and Canada Accords. It would make sense that the on/off switch be located next to the driver.
On my 2009 Accord, I shut it off when I want more power on a take off, in dry conditions of course.
nope (sorry for the late feedback), it's confirmed i do NOT have a VSA switch to allow me to turn it on and off at will. However my car DOES have VSA for sure, has the VSA light and the "!" light and i can feel and see wen it kicks in. So i guess we'll have to get into the "under the hood" solution of turning it off....
Any idea?
Any idea?
305_DB7ish
Mar 16, 2015 10:34 AM
89_honda_accord
Jan 26, 2005 11:43 AM
spencedogg
May 19, 2003 11:11 AM
