90 crx si seats in 89 dx hatch
Old Sep 22, 2002 | 10:21 PM
matt j's Avatar
Default 90 crx si seats in 89 dx hatch
need to know if i have to do anything custom or if they will bolt in, do i have to swap rails also?? let me know i am buyin on tuesday
Old Sep 22, 2002 | 10:26 PM
spettinger's Avatar
Default Re: 90 crx si seats in 89 dx hatch (hybridturbo89)
i don't think they work, my 91 hatch SI seats would not work in a 88 HF crx. the seat brackets MIGHT bolt up, it is odd for honda to change parts between similar cars and trim levels.
Old Sep 22, 2002 | 10:30 PM
illusive's Avatar
You have to do something custom they will not work as they sit. Only one hole will line up. You have to do some crazy brackets or drill holes through the floor or mess around alot with the stock rails on each seat. Its alot easier to just try to find 89 seats. Its a pain in the rear but can be done. I am waiting for some myself.
[Modified by illusive, 7:31 AM 9/23/2002]
Old Sep 22, 2002 | 10:46 PM
xtrafastcivic's Avatar
Default Re: 90 crx si seats in 89 dx hatch (illusive)
i did it 91 si seats in a 88 hf..
that bump on the floor needs to be cut or pounded down...
then a bracket on the back for the new seats...
the 90-91 seats have longer mounting points...
the bump is too close you can move the bump back if you can weld..
only the inner rail doesn't fit..
and no the seat rails can't be switched..
Old Sep 23, 2002 | 12:38 AM
illusive's Avatar
Default Re: 90 crx si seats in 89 dx hatch (XtraFastCRX)
They can be switched a guy I met took his 88 rails off his old seats(by force) and some how mounted them to 92 civic seats. I forgot how he did it, but it worked looked nice.
Old Sep 23, 2002 | 06:10 AM
Kato7997's Avatar
I think the CRX SI seating position is much lower, am i wrong??
Which seats DO bolt in??
Old Sep 23, 2002 | 07:10 PM
matt j's Avatar
Default Re: 90 crx si seats in 89 dx hatch (Kato7997)
what if i drilled new holes in the si seats to properly mount them?? would they work then and will i have any problems later on
torontocrx
Feb 24, 2005 02:04 PM
chadmasterc
Apr 17, 2004 12:57 AM
HGZ
Mar 29, 2004 02:10 PM
b16acrxer
18
Dec 4, 2003 09:58 AM
illmeth0d
Apr 13, 2002 04:18 AM
