I need help fast!
Old Dec 10, 2010 | 08:51 AM
d15b7inEF's Avatar
Default I need help fast!
Ok i am doing a MPFI swap on my STD and I have everything figured out except the FITV plug. Its on the back right side on the manifold...
Someone please help.
Old Dec 10, 2010 | 08:47 PM
d15b7inEF's Avatar
Default Re: I need help fast!
Bump anyone.... I have found write ups that mention the FITV... I think its called a fast idle temp valve i believe but not for sure. It is on a CRX IM and I dont have a plug for it on my STD harness. I need to know where these two wires run when doing a DPFI to MPFI Swap...
Thanks in Advance
Old Dec 10, 2010 | 09:44 PM
walkenman's Avatar
do you have a picture that showes this valve? I looked on mitchell and don't see a fast idle temp valve in the wiring diagrams
Old Dec 11, 2010 | 06:39 AM
d15b7inEF's Avatar
Its a fast idle thermal valve... some intakes have them and some don't let me find the only website I've found to talk about them....
Old Dec 11, 2010 | 06:46 AM
d15b7inEF's Avatar
http://www.fourthgenhatch.net/mpfi.html
Its shown and mentioned on this website but nothing is said about wiring or anything. Can someone please help?
Old Dec 11, 2010 | 06:51 AM
d15b7inEF's Avatar
Damn I'm dumb ignore everything I just wrote. I don't have to use it but if I do it goes to b2 on the ecu with a ground. Thanks for your help tho its very much appreciated.
Old Dec 11, 2010 | 10:45 AM
hatchet_honda's Avatar
huh?? what are you doing? wiring a plug thats already there? the dx should have that already. you dont need it. there will be 3 left over plugs. 2 injectors and the fitv
Old Dec 11, 2010 | 01:59 PM
d15b7inEF's Avatar
I'm just going to figure out it when I do it if I have a plug then I will plug it in if not its not a big deal I know where it goes so that's good. But does anyone know what exactly it does with the intake.
ridin_on_rims
Feb 3, 2008 01:04 PM
Ahknodd
Oct 21, 2006 09:31 PM
DieMaster
Sep 1, 2005 12:39 PM
MAYHEM
Feb 20, 2005 07:20 PM
honda8882
May 6, 2003 03:32 AM
