99 4 cyl Tranny Bad or Pressure Switch?
Old Dec 9, 2010 | 07:36 PM
jdadams12's Avatar
Default 99 4 cyl Tranny Bad or Pressure Switch?
Car does a late shift from 1st to 2nd under moderate to heavy load and also from 2nd to first when downshifting around 5MPH. When accelerating, you can feel the car shift, but the RPMs climb a bit before slipping back down - it does not feel like a typical slip. The other gears shift great and the torque converter appears to be locking up fine.
I just did a 3x drain and refill, but the old fluid was fine.
Is the tranny bad, or is it worth a 2nd clutch switch change?
Can anybody confirm that the 2nd gear clutch switch is 28600-P6H-003.
Thanks for the help.
Old Dec 10, 2010 | 03:04 AM
Turbodude06's Avatar
Default Re: 99 4 cyl Tranny Bad or Pressure Switch?
Good question cause I'm having a similiar problem.... https://honda-tech.com/forums/honda-accord-1990-2002-2/1994-honda-accord-transmission-acting-up-2871525/
Old Dec 10, 2010 | 07:01 AM
jdadams12's Avatar
Yours appears to be TCM related. I replied on your other thread.
10w30
Aug 1, 2018 07:04 AM
mikie_st
May 13, 2011 04:54 AM
andhoova
Sep 1, 2010 01:27 AM
chirp2hrd
10
Jan 1, 2003 09:47 AM
