need help bad for 93 accord
i have a 93 accord dx when you drive it down the raod it goes through the gears good BUT when you get up to speed and you start to give it gas to stay there the car dont wont to go if you put the paddle to the floor boom your off but it goes right back to the same problem now i have put alot of parts on it i started off with plugs plug wires the cap the button a speed sensor fuel filter fuel pump fuel presure regulator tps sensor a new key switch harness butnothing has changed can anyone tell me what i need to do the check engine light works but it does not come on so i know it want give ne a code can anyone knows how to fix this problem because i NEED HELP BAD
the car idles fine while its in park and not to bad while in drive it runs good when its cold do you think the map sensor is going bad or is bad because it only works when your driving down the road
yea it has a bad hesation when your driving down the road but it dont do it all the time just about 95% of the time hell i cant figure this out ive done replace everything but the motor and tranny i must be missing something or over looking something i done cleaned out my egr passageway ports because my egr wasnt working when you engaged it by pulling up on the plunger i think my hole danm intake is cloged up but i want someone on here that can help me because it may be something else and i really dont want to pull the intake its not that i cant it just not a lot of room for this lol so what do you think
Mcorson1101
Sep 3, 2013 09:57 PM
garfunkle55
Jun 14, 2007 10:26 PM
00WhiteEKy
Apr 25, 2003 09:39 PM
