96 ITR caliper rebuild
Hope all is well and everybody is having a great holiday season first of all. I have an interesting question however concerning the 1996 spec ITR front calipers and figured this would be the place to ask. I have this hub conversion done to my civic and am wanting to rebuild the calipers in the front. My question is, what rebuild kit would I use? I ordered a GSR rebuild kit thinking that they are the same. I thought this because they accept the same brake pads, and look physically almost identical. However, upon further inspection of the rebuild kit and the caliper itself I have found that the actual piston itself on the 96 spec ITR caliper is actually smaller. Is there a part number that I can cross reference to a USDM part number to use on these calipers? OR am I going to have to contact a gasket and seal company to see if they have something available in these dimensions, or worst case see if they can make me one. Anyways I hope that somebody has some direction for me here because they caliper is already apart and I cannot reassemble it until I figure this situation out.
Thanks in advance!
Ethan
Thanks in advance!
Ethan
I was frustrated by this question so I talked to one of the techs that work at the honda dealership i work at. he said he would start checking each car that came through to see of the calipers looked similer and had similar piston sizes to the 96 itr calipers i have. Sure enough an 06 civic non si came in and he found an almost identical caliper from bore size to piston size to even the same cast number in the back of it, 5410. He also mounted up my caliper to the passenger side and it was a direct bolt on to the 06 civic. so i went back in found the part number for the rebuild kits, 01463-S5D-A00 is what i came up with. I have already rebuilt one side with them and they went together nicely.
here is all of the cars that the rebuild kits are used on (i dont know if this means they are the same caliper but the rebuild kits are the same):
CIVIC 2001 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPEC.ED/SIDESRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPEC.ED/SIDESRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2006 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2002 3 SI 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2002 3 SI (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2003 3 SI 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2003 3 SI (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2001 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 GX (ABS SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX-CAR (CAR SHARE) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (ABS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (ABS/SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX-CAR (CAR SHARE) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2006 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (TRANS-#MPCA-2**) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX (TRANS-#SPCA-3**) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
4dooreg-k
Suspension & Brakes
11
Feb 28, 2011 07:19 PM
